What Aftermarket Rear Shocks You Got? How Do You Like Them?
Discussion in 'Hangout Lounge' started by RickCoMatic, Dec 1, 2006.
  1. RickCoMatic
    I need to know what aftermarket shocks you popped for ... what you spent and how you like them?
    I'm looking for a new shocks to replace the ones on my 750 Max.
    I desire all the great multiple features in suspension and damping available to the motorcyclist who wears "George Foreman Comfort Fit Jeans"
  2. bosozoku
    bosozoku Member
    Albany, Oregon
    I put a set of Works Performance shocks on in 1993. They no longer carry that particular version, which was at the upper end of their selection at that time, and cost $135.00. I had them make the shocks 1/2" longer to help reduce some ground clearance issues I was having while chasing friends on faster bikes. :roll:
    These are the closest thing in their current catalog to what I've got.
    They were a big improvement over the stockers. Works Performance will set the spring rate(s) up for your bike and riding weight.
    I had these same shocks freshened up a year ago, and Dave, my suspension guru, said they had normal/minimal wear. All that was needed was new seals and fluid.
    Whatever you decide to get for shocks, don't be afraid to spend a bit more than you anticipated...it's worth it every time you ride.
  3. spinalator
    spinalator Member
    Regina, CANADA
    Re: What Aftermarket Rear Shocks You Got? How Do You Like T
    I bought some cheapos (79.00?) from Mikes XS and they work resonable well. I think they are marginally better than the stockers.
    If I wasnt such a tightass I would like something with piggyback and more adjustability, but I really do not deserve having good suspension yet.
    MIkes XS shock page
  4. RickCoMatic
    I'm dialed-in on the performance to price ratio. I popped for some Koni's to replace stockers on a 650 Special. Those baby's were really nice.
    I like the ones in the Link. Are they Works? I'm addicted to Aluminum and that clean look. I'll even buy the Billet pretty-piece and polish it myself. The threaded pre-load is a beautiful thing; too.
    Don't even spoil-it for me by Posting the Price Tag. Let me get the Sticker Shock; later!
  5. Robert
    Smokamoto bought the JCWhitney set for his XJ, he has since put them up for sale. Said the spring rate was too hard. Smoke, could you elaborate please?
  6. Polock
    i put a set of '03 HD Dynaglide shocks made by Showa on a 81 kz550, the springs were way too stiff but the stock ones fit like a glove
    if the ends,length and springs are right, they work, hd shocks are common on ebay
    might want to expand your search
  7. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    Ikon shocks (former Koni) http://www.ikonsuspension.com/ seems most recommended here in Europe. An XJ1100 driving friend put on 7610SP8 (cromed, progressive springs, 4-step adjustable rebound dampening on top and 3-step spring preload at the bottom. He´s very happy.
    I´ll be putting on the same, bought used on Ebay Germany for about $120 shortly - won´t be able to review them ´till spring though...
    There´s a couple of Harley SP8 Konis on Ebay right now - although their 13" lenght might be too long for your bike. (If you get the model no., all datas can be found on Ikons Hp..) http://cgi.ebay.com/ebaymotors/HARLEY-E ... dZViewItem
  8. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    well got them on today and went for a test ride. 1.st impression is Wow; it´s a whole different league than stock and riding is a new experience (despite needing new tyres and front forks redone). The shocks absorb bumps alot better - the ride feels softer, yet more stable. Very pleased so far. Only adjusted the upper preload setting to "2" out of four. The 3-point setting at the bottom is in it´s softest setting but I strongly feel the characteristics won´t change much by making them stiffer - think it´s the progressive bliss 8)
  9. unkeldunkel
    unkeldunkel New Member
    Davis, CA
    I'm running progressive 12 series with the heavy duty springs. I really like them. Made a huge difference in handeling, as anything would be better than 24 year old shocks. They cost me about 180 from http://www.mawonline.com/ and would definately get them again.
