What am I?
Discussion in 'XJ Technical Chat' started by jammer41, Apr 29, 2010.
  1. jammer41
    jammer41 Member
    Rochester, NY
    Found this while emptying my oil pan today. Is it from a fork? That's all I could think of.
  2. Alchai
    Alchai Member
    Orlando, FL
    Your oil filter has a spring similar to that.
  3. jammer41
    jammer41 Member
    Rochester, NY
    Well, That might be it, I changed the oil and filter when I changed the fork oil.
  4. RickCoMatic
    If you just dumped the Oil Filter Dome into a Container, ... Fish around with a Magnet and see if you can find the Large Flat Washer that goes along with that Spring.
    The Spring and Flat Washer are used in conjunction to apply pressure on the Oil Filter to keep the Oil Filter in Place.
    Th Old Style Filters were all Cardboard and Paper. The Flat washer Kept the Filter in Place and the Spring from collapsing the Filter.
    Look at the Parts Site and see how they are placed inside the Oil Filter Dome.
  5. stereomind
    stereomind Active Member
    Tulsa, OK
    Wow, there was a fiver in your oil pan? I'll have to check mine!
    :mrgreen:
    But yeah, that spring goes in front of the oil filter.
  6. jammer41
    jammer41 Member
    Rochester, NY
    LOL
    Yeah, i wish. Didn't see a washer so i will be checking again.
    Thanks guys!
  7. MiCarl
    Don't be too surprised if you don't find the washer. Many of them were thrown out with a filter years ago.
    I think replacement oil filter washers give Chacal a nice stream of beer money :wink:
  8. chacal
    Yep, that's the oil filter retention spring.......
  9. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    It looks like a five dollar bill to me. I think that's a funny looking paper wieight you have holding it down. How did money get in your oil pan anyways? LOL
  10. bigfitz52
    You want to get that back in there right away, even without the washer if necessary; right now your oil filter can flop fore and aft in the housing, sliding back and forth on the bolt. Not good for flow or pressure.
  11. parts
    parts Member
    prescott valley az
    Check the old filter-oil and surface tension can cause the washer
    to stick and it may still be there.
  12. jammer41
    jammer41 Member
    Rochester, NY
    Sadly it is long gone, like 3 weeks ago. And I also am stuck with a filter cover bolt that the PO had badly mangled so... I am SOL at the moment Figure I will get to it when I return from a 3 month trip I leave for on the 13th. Perhaps I will get the spin on filter kit from Chocal. Looks sweet
