what exactly makes up one of these megaphone mufflers?
Discussion in 'Hangout Lounge' started by schooter, Oct 12, 2008.
  1. schooter
    Alrite well i took off my Honda mufflers on my maxim, cleaned and polished them, and got my bike ready for the sportster mufflers on the way(thanks beanflicker). I started up my bike, WOW mix between harley and a crotch rocket. rode it, loved it, never backfired. and went about 5 miles, ears didnt ring, just fine.
    but anyways, i looked down the mufflers, and there was nothing in them! its just a cone with a hole at the end slitghly smaller than the hole that leads into it. Is this 1985 tech, or is there something im not seeing going to work here? or is all this muffler just an expansion for air and then it has to be forced through a smaller hole?
  2. Polock
  3. wizard
    Yeh, polock, LOL, "the other way" is exactly the explanation schooter needs.
  4. coachholland
    coachholland Member
    Georgetown, KY
    The "Other Way" link has to be the funniest thing I've read in a long time. I'm going to have to go back to my old DodgeTalk haunt and post that link. We always got a good laugh with making fun of the Civic ricer crowd and their Type R stuff.
  5. maxim82
    maxim82 Member
    Farmers Branch, Texas
    Nice! I do have some extra coffee cans in my shop.
    Do I have to use blue paint, or can I use red paint? My bike is red. :lol:
  6. jeepsteve92xj
    jeepsteve92xj Member
    Milwaukee, WI USA
    I never tried this on my red 92 Cherokee Limited.
    I may have to try this on my red 98 Cherokee Classic. It already has more HP than any run of the mill Non-RED Cherokee just by the paint alone, right?
  7. coachholland
    coachholland Member
    Georgetown, KY
    Only if you add a TypeR sticker to it Steve. That alone is worth 100HP.
  8. jeepsteve92xj
    Milwaukee, WI USA
    oh yea, I got markers! I could write TypeR on everything!!!
    may as well go for some weight savings and write LEXAN on all the glass! I can't imagine how that wouldn't be a huge help!
  9. bigfitz52
    Schooter; The mufflers could have been designed that way or there may have been an "obstructing" baffle in there that the PO drilled through. (Common mod no matter what bike.) I can look right through the stock mufflers from my Norton but can see louvers on the inside surfaces. I cannot look through the stock mufflers from my Secas, there is a plate about 3" in from the rear that blocks further viewing, and is part of the internal "chamber" system. Your mufflers are Honda, the only way to know for sure would be to find another one you know is original and look through it.
  10. TIMEtoRIDE
    Honda GL 500 has an empty megaphone with an endcap with a short 3/4 inch tube outlet with small holes in it.
    My '82 Maxim 750 has the endcaps removed, revealing an internal plate with (i think) 4 holes and (from memory) 2 have short tubes going further in.
    My 900 has this TINY aluminum glasspack. Surprisingly quiet at lower RPM 's
