What glue?
Discussion in 'XJ Technical Chat' started by knuts2a, May 12, 2011.
  1. knuts2a
    knuts2a Member
    I am finaly getting around to fitting a new sight glass to my master cylinder but chacol couldn't send the glue with it to Australia. What can i use that is brakefluid resistant to glue it in. I have seen on other forums Silastic (silicon based sealer) isn't anygood. :?:
  2. BillB
    BillB Active Member
    Tulsa Oklahoma
    Since no one else is on this. How about a experiment?
    I would suggest mixing up the two part clear epoxy, lay some in the bottom of a glass jar to set up then pour a little brake fluid in the glass jar and let some time pass. Check on it in a few hours to see if it is breaking down. If it doesn't, you have a fix. If it does...
  3. Polock
    try Three Bond Black 1207 B or hondabond , Wizard told me about three bond so you guys must have it down there
