What is the best clutch for my XJ650???
Discussion in 'XJ Technical Chat' started by r1pilot83, Sep 7, 2009.
  1. r1pilot83
    r1pilot83 Member
    I have searched the forum and havent found much about clutches. My clutch is grabbing when its cold when the bike is in gear and dying. I dont see any adjustment in the cable like my R1 has. My clutch looks really worn but isnt blue. What does a good clutch run and who should I go with?
    Thanks,
    Steve
  2. r1pilot83
    r1pilot83 Member
    I took tolerances tonight on my friction plates and they vary 3.0 to 2.9. 2.8 is the standard for replacement. I cant believe nobody knows of a good clutch for this bike.
  3. Polock
    why not just put oem stuff back in it ?
  4. r1pilot83
    r1pilot83 Member
    Thats what I am asking really. I want to know if oem is the best replacement for longevity and function. Some yamaha oem clutches slip quickly if they are abused, and some aftermarket clutches dont last long if they are abused. Just thought I would ask. Not a lot of response.
  5. bigfitz52
    We don't know what bike you're referring to or how many miles are on it, etc.
    The Yamaha OEM clutch works quite well, as do the "aftermarket" parts that chacal carries, they're made by K & L.
    My '83 Seca 550 has a clutch that's made up of OEM plain plates (original, resurfaced with Scotchbrite) K & L friction plates (from chacal) and OEM springs. It works just fine and didn't cost an arm and a leg.
    OEM or stock aftermarket should work fine; be sure you replace the springs and to be safe, the bolts.
