What is this and why is it smoking?
Discussion in 'XJ Technical Chat' started by serialboyscout, Sep 28, 2009.
  1. serialboyscout
    serialboyscout Member
    Salt Lake City, Utah
    What is this filter in the attached picture for? I couldn't find it in the Haynes manual I have. It has a connecting tube that runs down to the gearbox(?) and must pull air? But I have no idea.
    Also, and a bigger issue, why does it smoke when the bike is warm?
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    That is your crank case breather vent. It at one time was hooked up to the airbox. The smoke can be from blow by. Do a compressions check.
  3. SQLGuy
    SQLGuy Well-Known Member
    Keep in mind that the reason it was hooked up to the air box was for PCV. That vent hose is normally supposed to pull gases from the crankcase back into the intake to be reburned.
    That's why I kind of laugh when I see these little filters that people put on them after converting to pods. Those filters are filtering gases getting blown into the atmosphere, not filtering air going into the crankcase.
    It would make perfect sense that this smokes a bit, just as you would see a bit of smoke if you open the oil filler while the engine's running. If it's smoking a lot, that may be more of a cause for concern.
  4. TIMEtoRIDE
    They used to call it a road tube, before 1964.
    Cars would just spew onto the road.
    We were so unevolved !
  5. Zookie400
    Zookie400 Active Member
    Connecticut
    up until 2007 diesels still had draft tubes puffing away and dripping oil.
    i put a filter on mine to keep the bugs from making a nest in the hose and clogging it, otherwise SQL is correct its not filtering anything.
  6. Bushy
    Bushy Active Member
    Its filtering out the bugs while it sits in the garage.
  7. serialboyscout
    Sweetness. I think I may need to do a compression check as it can smoke quite a bit when just sitting at idle.
    Thanks for the replies.
