What is this on the carburetor ?
Discussion in 'XJ Technical Chat' started by Rammstein86380, Jan 3, 2024.
  1. Rammstein86380
    Rammstein86380 Member
    France
    Hi
    I look my carbs and i see that (in red)
    I think it's vaccum but where i do connect that ?
    I know i need to put a vaccum hose between the boost sensor and the plenum (down of the plenum)
    Another one between the fuel pressure regulator and the plenum (UP of the plenum)
    But i don't know what is this hose
    Thanks a lot
  2. Simmy
    the nipple on carb 2 is the green line. This should go directly to the boost sensor.
    Below is how I had mine set up with a boost controller.
    I've since eliminated the boost gauge and the boost controller so there is a direct line from the carbs to the boost sensor.
  3. Rammstein86380
    France
    Thanks a lot
    The hose under the surge tank is drain hose ?
  4. Simmy
    correct, but it has a valve which needs to be rebuilt.
    It will drain any oil/fuel residue at atmospheric pressure but seals up when under boost.
    XJ4ever sells the foam filter and gaskets for this.
    I guarantee your filter will be disintegrated.
  5. Simmy
    here is the replacement gasket and foam filter from XJ4ever
  6. Rammstein86380
    France
    Thanks it's a foam, a papier gasket and one oring ?
  7. chacal
    Rammstein86380........I replied to your e-mail of a few days ago and it bounced back as a bad address. I've sent the same info to you via this website's Conversation service, so you should look at your Inbox to retrieve the information you were seeking.
  8. Rammstein86380
    France
    I clean the valve but how Can i test that to see if the valve is ok ? With comprimed air ?
