What is this
Discussion in 'XJ Technical Chat' started by Hosethe3rd, Apr 26, 2012.
  1. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Hey I am working on a 550 and there is no turn singel could this be it? Please help I just want to ride
  2. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Here is the pic
  3. Kaya
    Kaya Member
    Wisconsin
    Looks like a flasher relay.
    And yes, it can cause your non signaling signals.
    -Kaya
  4. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    thanks and does that control the head light
  5. Kaya
    Kaya Member
    Wisconsin
    I dont think it would...
    I cant say 100% its the flasher relay. It just looks like it.
    Its under the gas tank near the front of the bike right under the ignition coils. Need to look under top part of frame. It is hard to find when your not sure where to look.
    -Kaya
  6. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    yes it is and i think it does control the head light on my bike
  7. Kaya
    Kaya Member
    Wisconsin
    I suppose it might?
    It appears its a different relay?
    -Kaya
  8. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    there are two the one with the stripe wires are in the back but the one with the solid wires are in the frount under the tank
  9. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
  10. bigfitz52
    The relay locations differ between bikes.
    Is it a 550 Seca, or 550 Max?
    The headlight relay DOES NOT have anything to do with the turn signals, and the turn signal relay IS DIFFERENT than the headlight relay.
    The 550 does have a headlight relay (some XJ bikes don't) that only allows the headlight to come on once the bike has been started.
  11. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    it is a maxim the only thing the head light come on if i switch the yellow and the blue
  12. Kaya
    Kaya Member
    Wisconsin
    This is your headlight relay :
    the wires to it should be white, black, red w/yellow stripe, blue w/black stripe.
    And if your flashers arent working, the its safe to assume that its the relay that is under the coils.
    I wish I could be more help, I suppose you could check to see if your getting power to the relays with a multimeter.
    If you are getting power to the relays, and if your comfotable soldering, then you can open relays up and repair them. They are not really that advanced of devices. Chances are the connections inside have either rusted out or corroded to a lovely greenish white color. Clean them up, and many times you can save a costly replacment.
    *Edit* If anyone can solve this issue its Fitz. Hell take care of ya.
    -Kaya
  13. bigfitz52
    Quit crossing wires before you cook something.
    PM me with your email address and I'll send you the necessary reference materials.
    The headlight SHOULD NOT come on until the motor is running.
  14. slomo85
    slomo85 Member
    Imperial Beach, CA
    Yup, my headlight doesn't come on until my bike is running as well... I say follow the fitz!
    granitize likes this.
  15. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    I got it all working now! One more thing what is the best way to put the carbs back in on a 85 xj700x maxim x
