What kind of spark plug cap?
Discussion in 'XJ Technical Chat' started by Maxim700, May 18, 2006.
  1. Maxim700
    Maxim700 Member
    Sackville Nova Scotia
    I thought I read that we needed resister type is this right?
  2. Robert
    The 5K (5,000 Ohm) is recommended with a copper core spark plug wire. Do not use them with the carbon core wires.
  3. Maxim700
    Maxim700 Member
    That is what I thought. I have the original coils and three of the caps seem to be sealed to the wire. The 4th cap is different and is a push on type.
    Do I just cut the wires where they enter the old caps or is there another way to disconnect them from the caps.
  4. Robert
    They should unscrew. What necessitates their replacement? Cracked, corrosion?
  5. Maxim700
    Maxim700 Member
    At least one of them leaks. after a rain last week the bike didnot want to start. it always starts!
    There is also the fact that I have 3 original and 1 different caps .
    Do they unscrew inside then pull the wire out?
  6. Robert
    If they are the original NGK caps, they should unscrew like a screw from the end of the cap, kinda like a tube of toothpaste.
  7. regulator
    regulator Member
    Ankeny, IA & Brooklyn Center, MN
    I had put NGK caps on mine, and had a crack in the "plastic" of the cap causing spark to jump, just for kicks and to see how they looked went with caps found at JC whitney that show everytime spark hits, have had great success with them, and you can see how strong or weak the spark is. plus looks cool especially at night LOL
  8. Foximus
    Foximus Member
    Orlando
    what are these caps called? I couldnt find them on their site.
  9. Jazzmoose
    Jazzmoose Member
    Pineville, LA
  10. secaman
    secaman Member
    guatemala, central america
    yep i used to have them on my jawa,
    abd they're real fun to watch!
  11. regulator
    regulator Member
    yea those are them, nice to see if you loose spark, and definately have people looking at night
