What sizes do I need?
Discussion in 'XJ Technical Chat' started by Donglord, Aug 11, 2025 at 12:50 PM.
  1. Donglord
    Donglord Member
    Arkansas
    I quadruple checked every clearance and these are my measurements. The smallest feeler gauge I had was .03mm, so I just put 0mm for when I couldn't get the feeler gauge in there. Is there a chart where I can determine what sizes I need, or can someone elighten me.
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Start a conversation with me and send your email address and I will send that excel sheet to you.
  3. Donglord
    Donglord Member
    Arkansas
    Message sent. Thank you
  4. chacal
    It is extremely odd that ALL of your intake valves have zero clearances, whereas all of the exhaust valves have correct or almost-correct clearances. How many miles does this engine have on it?
  5. Donglord
    Donglord Member
    Arkansas
    I'm unsure of the miles unfortunately, since the bike didn't come with the original speedometer and tachometer. Can j ask why that's so odd? As my post says I put 0mm because I couldn't fit my .03mm gauge in there.
  6. chacal
    Well, even not being able to get a 0.03mm feeler in there means the clearances are (as Tuco would say) tight-tight-tight. It's the contrast between the intake clearances (which are basically right where they should be) and the exhaust clearances which are so tight. While it is normal and expected for clearances to decrease over time (with engine mileage accumulation), for them to be so inconsistent on the intake vs. the exhaust side is odd. While there are reasons why that may have happened due to human issues (i.e. someone checked and adjusted all the intake pads, but none of the exhaust!), it's hard to understand it due to mechanical (normal engine operation) issues.
    Or somehow, you're method of checking the clearances was amiss.
  7. Donglord
    Donglord Member
    Arkansas
    I don't think I measured incorrectly. However, I know nothing of the bikes history, as I got it on a trade not even a year ago. The bike looks like it's been through a lot of hands though. I think it's had a rough life and perhaps that could be a reason why the clearneces are so funky.
  8. Simmy
    Just hypothesizing here but since exhaust valves are typically smaller than intakes the same forces are working against less valve seat.
    Also much hotter gasses flowing over the seats on the exhaust side.
    My last KLR needed just exhaust shims, intakes we’re still in spec.
