What weight oil in a 1982 750
Discussion in 'XJ Technical Chat' started by Jonnierock, Apr 25, 2016.
  1. Jonnierock
    Jonnierock New Member
    Wisconsin
    My son bought a 1982 750 Maxim. Does anyone know what weight oil he should use when changing . He does have a manual coming but until then he'd like to change oil
  2. a100man
    a100man Well-Known Member
    Bedford, UK
    I think most folk use 10w40 but it should be for wet clutch applications and not standard car oil - JASO MA will be written on the tin if it' s good.
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I use Shell Rotella 15/40 and have not had any issues.
  4. Chance
    Chance Member
    Rockland, Ontario, Canada
    In my xj550 I run Lucas Motorcycle oil 20/40
  5. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I use the same.
  6. waldreps
    waldreps Active Member
    Henning, MN
    I use the same as well.
  7. Jetfixer
    I use Valvoline 10W40 Motorcycle oil.. Autozone, Advance auto both carry oil.
  8. k-moe
    Choose the weight of oil that meets the needs of your riding conditions (ambient temperature). Otherwise just make sure (as mentioned above) that it is JASO MA rated.
  9. skiprrdog
    skiprrdog Active Member
    Tucson, AZ
    +1 on Rotella, and its only $12.97 /gal at WackoMart :)
    Chance likes this.
