Whats this and how to remove it
Discussion in 'XJ Technical Chat' started by redlightningsvx, Jul 14, 2012.
  1. redlightningsvx
    redlightningsvx New Member
    How do I remove this plate to change the metal gasket?
  2. DrFate
    DrFate Member
    NE Kansas
    disconnect the drive shaft, unscrew the four bolts, and loosen the two engine studs immediately above it. It should pull out straight out with some force. Those plates behind it are actually thin half-circle shims - is that the metal gasket you're referring to?
  3. redlightningsvx
    Yea thats it. The motors out and already pryed a bit on it with no movement. Figured I would check here before I break it. Thanks
  4. bigfitz52
    SHIMS. Not a gasket. Shims.
    You don't just arbitrarily "change" them; you'll screw up gear lash or bearing float within the middle gear box. Don't lose them and keep track of the order they came out in.
    YOU NEED A SERVICE MANUAL before you do hurt something.
  5. redlightningsvx
    I got a service book but didn't mention the removal of this. Was going to replace them cause there a little beat up/bent.
  6. DrFate
    DrFate Member
    NE Kansas
    +1 on what BigFitz said - you shouldn't have to replace those unless you check your gear lashing and find you need to. The haynes manual is pretty descriptive about how to do that.
  7. bigfitz52
    Again; they're SHIMS. If the part you can see is a bit beat up, NO BIGGIE.
    I highly recommend you leave them alone. That's an adjustment you don't need to "break."
