Whats this thing called :)
Discussion in 'XJ Technical Chat' started by Myck, Sep 13, 2015.
  1. Myck
    Myck New Member
    Perth
    hey guys whats this called, positive lead from battery goes to it.
    the 2 small wires have no power coming from them and the bike wont turn over. no response from ignition button.... could this be the problem???
    cheers guys
  2. YamaMax82
    YamaMax82 New Member
    Oakland, CA
    Looks like the starter relay switch.
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Starter solenoid
    If you apply 12 volts to the two small wires it should click and the starter should turn the engine over. So hook it back up, ground to blue and positive to red and see what happens. If it turns over you will have to check the side stand relay and the wiring back up to the start button. You should post which bike you are working on and maybe someone will post a wire diagram here for you.
  4. XJ550H
    what model bike do you have
    you connect positive from battery to one nut and the cable from starter to the other nut.
    the connector from the harness has the voltage on one pin and the wire runs back to the starter button on the other pin . when you press the start button you make a connection to ground
    test for voltage at the harness connector and check for continuity to ground when you press starter button
    the blue wire should be button red wire voltage
  5. Myck
    Myck New Member
    Perth
    Thanks for that guys, it will give me a few things to test tomorrow
    The bike is an 1983 xj750 police model
    Going to see about making a new wiring harness aswell as this one looks a mess
  6. XJ550H
  7. k-moe
    Regardless of condition, I am officially jealous. Does it have that cool digital speed monitor above the ATARI?
  8. Myck
    Myck New Member
    Perth
    Yeah Mate I will grab a picture of it today for
    I sure does mate
    Stumplifter likes this.
  9. XJ550H
    what does digital speed monitor do?
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Monitors speed digitally, of course!
  11. XJ550H
    so two spedo's one analog one digital? our tax dollars at work
    would be sweet if it had built in radar.
  12. MattiThundrrr
    I don't actually know. I was just being me (a jerk). Built in radar seems improbable, but who knows? Somebody, I hope...
  13. XJ550H
    no jerk just humor,
  14. k-moe
    It helps the officer fill out your speeding ticket.
  15. Myck
    Myck New Member
    Perth
    Cheers XJ550H I missed your post about the wiring diagram, Thats exactly what I have been needing :)
