What's up with these front rotors?
Discussion in 'XJ Technical Chat' started by Desinger_Mike, Jul 29, 2009.
  1. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
  2. TIMEtoRIDE
    Looks just like my "new" Venture front rotors. Lots of slots.
    But I think grooves that don't go all the way thru are better.
  3. bigfitz52
    So those aren't stock for an '85 700? They sure look the part, I wouldn't have guessed. I think they're from a different bike rather than aftermarket.
    TIME is right; "channels" are the current hot setup. However, I believe it's Audi, has teeny tiny holes in their channels (on the racecars.)
    I can tell you that a drilled stock POS Yamaha front rotor does work a bit better than in its original form. The EBC floating rotor discs made with correct modern metals are the easiest way to completely upgrade the brake. But they're not slotted.
  4. Desinger_Mike
    I've never seen an 85 with slots standard.
    Also notice the big holes next to the mounting bolt holes (also not stock)...similar but different
    With a good MC, pads, and SS lines both mine will lock up the front wheel so I'm not looking for any upgrades.
    Or at least they will up to about 35 mph (I'm afraid to squeeze hard enough above that speed)
  5. helmet
    helmet Member
    On 2 wheels... just lost my hat.
    those arent factory on anything I have seen.
  6. redcentre003
    redcentre003 Member
    Those front rotors are exactly the same as mine.
    I have an (Australiasian) 1985 XJ900. The stock rotors were slotted and vented but they were too worn to pass a "roadworthy" test after I got it together and ready to be registered on the road.
    So...a visit to the wreckers turned up those exact same rotors. They're off a Yamaha model, possibly even in the 90's - can't remember - and they are the correct size (diameter) and have all the mounting holes in the right places. I think I paid around AUS$60 each (presses calculator buttons...), that's about US$75 each.
    They were in good order and barely worn at all. Check around and you'll find that some later model Yamaha rotors can be interchanged on at least my 900, Rick's '83 900 and probably other XJ models like the 700.
    Cheers.
  7. Hillsy
    Hillsy Member
    Wow - can I borrow your calculator next time I buy something from the States?.... :lol:
    Not sure what model they are off, but they are DEFINITELY Yamaha spec. I think the early FJ1100's had them (??)
  8. markie
    markie Member
    Suffolk, England
    They are also fitted to the UK/Europe model xj600 which is what I ride. Rear brake is a smaller diameter of the same design.[​IMG]
    Hope they show up ok? You can see the rear fairly clearly.
  9. railtrolley
    railtrolley Member
    Melbourne, Australia
    They are exactly the same rotors as fitted to my bike, which I believe are the original rotors. The rear rotor, though, is the same as fitted to the U.S. XJ900RK. Yamaha probably didn't see any need to update it.
  10. truckerbikes
    truckerbikes Member
    queensland australia
    10 points for those who said they came of a yamaha. originally these were fitted to the xj 600/650, and 900r. they are the same size and spec for most seca models. these are the units that i changed to after having a near miss with the old solid ventilated units. bolt straight on and the stopping performance is something else. if you can find these and they fit your bike do youself a favour and grab them, you won't regret it.
    sad to say i don't think they will fit the earlier maxims
  11. truckerbikes
    truckerbikes Member
