Wheel Spacing
Discussion in 'XJ Technical Chat' started by Tony7745, May 18, 2015.
  1. Tony7745
    Tony7745 Member
    Jersey Mills, PA
    My bike fell off the center stand while on a slight angle with the forks turned towards the road. It pushed something to the right about a 1\4 of an inch. The forks are square with the bars, the rotor is almost hitting the inside of the forks. Long story short, should the inner spacer between two bearings have play. Or does it sit in there and ride on the axle.
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Which model?
    Gary H.
  3. k-moe
    The spacer between the wheel bearings should be a tight fit. It gets pinched by the bearings when they are fully seated so that the bearings don't collapse when the axle nut is tightened.You should be able to slide it fore and aft with a screwdriver, but not be able to tip it or pull it from side to side.
  4. rocs82650
    Middle Tennessee
    There should be enough space to tip it just enough to get a drift pin or cold punch on the lip of the bearing. (old school bearing removal procedure).
    Gary H.
