where do i get piston rings?
Discussion in 'XJ Technical Chat' started by Johnxj900&cb1100r, Nov 27, 2017.
  1. Johnxj900&cb1100r
    Johnxj900&cb1100r New Member
    Bribie Island
    I have a very early XJ seca 900 1983 engine...(number 13 in fact)..that i would like to rebuild as a spare.
    I would appreciate someone letting me know where piston rings for the 853cc engine can still be obtained. Thanks
  2. hogfiddles
    Johnny-- I manage the database for 900rk USA-delivered units....
    I own the lowest serial delivered here.
    What does your serial read after
    JYA---
    (Next three characters)
    Also, how do you know yours is #13?
    Thanks Dave Fox
  3. chacal
    We have them in stock! Send me an e-mail (info@xj4ever.com) or use the "Start a Conversation" feature on the website to contact me for more info.
  4. Johnxj900&cb1100r
    Bribie Island
    Dave, Thankyou for your reply. My engine number is 31A-000013. Its an Australian delivered engine.
    Regards
    john
  5. hogfiddles
    Interesting.....are you sure it's 000013, not 000113?
  6. Johnxj900&cb1100r
    Bribie Island
    Positive Dave. Its a very very clear stamping....I can send you a photo if you would like. What is your lowest number on your register Dave?
    Regards,
    John
  7. hogfiddles
    Interesting, because for the USA-delivered units the serial#'s began with 000101.
    I'll send you a conversation so particular info doesn't go out to the whole wide world.
    Dave F
  8. k-moe
    IIRC the serial numbers are of a different series when the engine prefix is different. There will be "doubles," because the machines were built for different markets. The start-point would likely be different as well since pre-production work would have already been done, so no need to build more pre-production bikes for testing purposes.
  9. hogfiddles
    Be interesting to hear what Len says....
    I saw a pic......yes indeed -- it does show 000013
    Here's 31A info from the information overload hour for comparison/discussion:
    COUNTRY: EUROPE
    MODEL NAME: XJ900F
    STREET NAME: 1983 XJ900
    MODEL ID CODE: 31A
    FRAME ID: 31A
    SERIAL NUMBER STARTS AT: 000101
    NOTE: 853cc engine, handlebar-mounted fairing, belly pan
    Dave F
  10. Johnxj900&cb1100r
    Bribie Island
    Remember this is an Australian delivered engine
    John
  11. chacal
    I can't find ANY XK900 models (31A or otherwise) that had serial numbers starting below 000101............but, it obviously happened, so it's either due to:
    a) bad info regarding what the starting serial numbers really were
    b) yours is an anomaly. Do you know whether this engine was in a matching-numbers frame?
