Which one do I have.
Discussion in 'Hangout Lounge' started by engraverwilliam, Jun 8, 2014.
  1. engraverwilliam
    engraverwilliam Member
    Baldwin Hills, South Los Angeles
    I have a 82 maxim 750 but when I look at the service manual there are several letter combos that follow the xj750 description.
    RJ and RK K MK J UK?
    I am receiving some 3 wire front turn signals and I need to figure out which schematic to use so I can find the right color combo in the rats nest behind the headlight.
    this is her
  2. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Check the first 3 digits of the vin
    From chacal's catalog:
    750's:
    1982 XJ750 Maxim USA: 15R
    1982 XJ750 Maxim Canada: 15T
    1983 XJ750 Maxim USA: 22R
    1983 XJ750 Maxim Canada: 22T
    1983 XJ750 Midnight Maxim USA: 33N
    1983 XJ750 Midnight Maxim Canada: 33U
    1981-83 XJ750 Seca USA: 5G2
    1981-83 XJ750 Seca Canada: 5H2
    1985 XJ750 Maxim X Canada: 1FL
    1986 XJ750 Maxim X Canada: 1MY
  3. MiCarl
    Assuming it's the U.S. model it will be "J".
  4. engraverwilliam
    It is a 15R.
    Thank you.
  5. TIMEtoRIDE
    You need to get-use the 27 Watt bulbs for your turn signal, or the self canceller/flasher will not work right
  6. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    15r designates 1982 XJ750J Maxim......
    Someone replaced the square headlight bucket with a round one.......that round headlight is not standard on a 1982.....a square one is
  7. engraverwilliam
    Yeah, that one is me. It is the one from the Vetter fairing. It is just temp until I can locate a rectangle one and the little sub light that goes below it.
    I like the round look though. If a round chrome one comes my way first i will probably switch to that.
