whimsically loose valve clearances ?
Discussion in 'XJ Technical Chat' started by Devastruction, Aug 12, 2013.
  1. Devastruction
    Devastruction New Member
    Edmonton, AB. Canada
    Hey all ! , I was just checking my valve clearance on the bike I'm working on for the lady while i wait for the return of the frame and it seems that all my valve clearances are IN Spec or loose whimsically so on the intake side
    from what i have read this is very rare , and i am wondering what to make of it
    on the intake side ( after 3 rounds of mesurements )
    1).15 mm fit .2 didn't 2) .25mm fit .3 didn't 3) .20mm fit .25 didn't 4 .25mm fit .3 didn't
    on the exhaust side
    1) .15 fit .20 didn't ( in spec) 2) .15 fit .2 didn't ( in spec) 3) .20 fit .25 did not ( loose end of IN spec? ) 4) .15 mm fit .2 didn't ( in spec )
    so why are my exhaust valves pretty good and my intakes GAPING open?
    since they tighten with wear am I ok on the intake side ? or is it much too far out of whack
  2. RickCoMatic
    "Loose" ---> IN Specs is OK. ( Genuinely "IN Specs!!!)
    Loose OUT of Specs places you in jeopardy of "Throwing-a -Shim"
    Throwing a Shim is Bad News.
  3. Devastruction
    excellent RICK Thank you ! any idea why they would be so horribly loose on just the one side ? I am very skeptical that anyone has been in there for at least a while before she was parked and i happened across her
  4. bigfitz52
    Somebody before you may have used a certain manual that gives the wrong specs for the intakes.
  5. Devastruction
    Ahh good call Fitz thank you sir
