Why do I only have one disc up front? 1983 XJ750 Maxim
Discussion in 'XJ Technical Chat' started by Adam H., Feb 27, 2015.
  1. Adam H.
    Adam H. New Member
    Wichita Fall, TX
    Hi all, so in every picture and write up I've seen there are two brake discs up front, but I only have one! It's on the right side if you're sitting on the bike. It doesn't look like there ever was one on the other side - no brake line, just nothing. Any ideas?
  2. KDub
    KDub Member
    Burnley, NW UK
    Got any pictures? XJ650 Maxims only have one brake disc too, but it's on the left.
    On the left side fork slider, is there any provision for mounting a caliper?
  3. Adam H.
    Adam H. New Member
    Wichita Fall, TX
    I'll see if I can take some tomorrow, but since it's supposed to snow all day I don't know if I'll be able to. Also, just peeked out the window and I'm an idiot, brake is indeed on the left. Could someone have swapped in a 650 front end?
  4. hogfiddles
    • My bet is that someone swapped out the forks from a xj550rj seca.
  5. FtUp
    FtUp Well-Known Member
    pacific northwest
    the 550 seca has the brake on the right side and the upper tubes are only 35mm. I'm with kdub, I think it's a 650 front end. my 83 750 maxim has the double front brakes.
    CN
  6. hogfiddles
    CN.... He said the brake is on the right. 650 is on the left. I've had 750 secas come in here w/: 550rj fronts, 750 maxim fronts, an xz550 front, and even a 400rj front.
    I'm standing with what I originally posted.
    550rj front, probably swapped the triple clamps too
  7. FtUp
    pacific northwest
    text copied from post number 3:
    "Also, just peeked out the window and I'm an idiot, brake is indeed on the left."
    CN
  8. hogfiddles
    Ok, I'll have to give you that one...... Replied to he original post and hadn't read through the whole thread---- oh well.
    SO.......if its a single on the left, then yeah..... Swapped out for a 650 maxim
  9. cutlass79500
    lawrenceville georgia
    Someone did a no no and either hit something or had rusty forks. I am gonna be replacing the original front tire as well as lines going to ss and the master in the next few weeks hopefully 00q0q_5kuCetvJyDa_600x450.jpg
  10. hogfiddles
    Cyl 4 getting a little hot there, cutlass? Otherwise, it's looking nice!
