Wierd Starter Button
Discussion in 'XJ Technical Chat' started by 600ccmicrob1, Apr 6, 2009.
  1. 600ccmicrob1
    600ccmicrob1 Member
    South Central PA
    Most of the time my starter button works fine, but every once and a while i will push in and get nothing. Then I wait a few seconds after it does not work and it works fine. What could be the problem here?
  2. Grynen
    Grynen Member
    Holland Landing
    It could be a few things first thing that comes to mind is a dirty starter button. So that would be not a very good connection in side there and possibly causing the intermittent start.
  3. blame_the_po
    blame_the_po Member
    Boston
    these starter buttons are notorious for breaking off or just stop working. A lot of ppl change them out for different ones, or just put a starter switch somewhere else on the bike.
  4. TheHound
    TheHound Active Member
    Scotia, NY
    What Grynen said.
  5. MidniteMax
    MidniteMax Member
    Liberty SC
    My Midnight's starter button broke off and fell out. I saw that the retention ring/lip had broken off the thing.
    I am an electrical contractor and am fortunate enough to have several size wire nuts in stock. I cut a correct sized ring out of an orange nut (color-coded by size), pressed it onto the button and glued it where the retention ring had broken off. Note, this is a hard, not soft and flexible wire nut.
    I took the switch assembly apart and installed my repaired button the other day. I also lightly sanded the contact surfaces as I had also experienced the delayed start syndrome as mentioned by others.
    So far so good.
    I will admit that I have doubts it is a long term fix, so I ordered a new starter switch from Chacal (along with some other much needed brake items).
    Anticipating my parts delivery soon.
