Will an XJ750 grab bar and factory side rails fit on an XJ650?
Discussion in 'XJ Modifications' started by The Original CruiserXJ650, Jun 17, 2016.
Tags:
  1. The Original CruiserXJ650
    The Original CruiserXJ650 New Member
    Alaska
    Looking at a used one with the factory side aluminum rail pieces that mount the shocks and a fabricated "handle" attached to the uprights. Would like some help getting it on the center stand and horsing it around when necessary! CruiserXJ650
  2. The Original CruiserXJ650
    Alaska
    Anybody? Is the rear frame of an XJ750 the same as an XJ650, as far as mounting points for the factory grab bar on the frame? Or, could I just drill new holes in the factory xj750 aluminum side rails? It looks like very nearly the same part, but I have no measurements. I noticed that there was no hole for the helmet/sear lock used on the 650, but I can drill that.
  3. k-moe
    The frames are different. The passenger grab rails are different.
    The real thing to have is a standing handle. Which XJ650 do you have (there were three sub-models)?
  4. The Original CruiserXJ650
    Alaska
    Mine is a 1980 (4H7 - 12xx serial), an early G Model if I read the info here correctly.
    CruiserXJ650
  5. k-moe
    You have a Maxim.
    They did not come with standing handles, but it wouldn't be much work to make one from steel tubing (electrical conduit would even work). Do you have a hammer, a drill, and a vise?
  6. The Original CruiserXJ650
    Alaska
    Yes, I do - I will look at other bikes locally to get an idea - I had just hoped for a bolt on solution.
    Thanks!
    CruiserXJ650
  7. XJ550H
    one end to shock stud bend to follow contour of frame other end to flasher light mount
    or similar to the rag around the shock method you could mount a leather strap to some location along the frame
