Wire Connectors
Discussion in 'XJ Technical Chat' started by robvoi, Dec 13, 2009.
  1. robvoi
    robvoi Member
    Question of the day from a newbie/wannabe:
    Headlight doesn't work ... I replaced bulb ... still no luck; the bike has been in the Seattlle rain for a few years (previous owner).
    I want to clean all the wire connectors and I must have a mental block because I cannot disconnect/take apart the wire connectors in the headlight bowl.
    How do I pull the connectors apart? i am sure that am missing something along the way ... like squeezing them in a certain way
    Anyone ... please help.
    Thanks!!!
  2. albran
    albran Member
    DFW, USA
    Probably the plastic has corroded together.
    Try some silicone spray, penetrating oil, etc.???
    After you get the connectors apart are you using contact cleaner and dielectric grease?
    ab
  3. MiCarl
    You didn't mention your model but on most of them the headlight won't come on until the alternator is producing electricity. So, if the engine isn't running or the alternator is defective there will be no headlight.
  4. robvoi
    robvoi Member
    thank you both for the insight!!
