wiring help needed
Discussion in 'XJ Technical Chat' started by Kevin A, Jun 26, 2016.
  1. Kevin A
    Kevin A Member
    hamilton ontario canada
    Hi guys i just purchased some aftermarket signal lights online . When i opened them up they had 3 wires coming from them. My factory ones only have 2 wires . Any ideas on how to wire them up? I would appreciate any help you guys can give me . Thanks
  2. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    I purchased 3 wire lights the first time I had to replace one. You can just leave the extra wire loose or hook it up as an extra running light. If I recall correctly, I left mine disconnected, but ran it through to the headlight bucket in case I wanted to change things in the future. However, I wouldn't bother if I had to do it over again, as it was a pain to get three wires through the passage.
    Kevin A likes this.
  3. XJ550H
    if you just go for the single light make sure it is the brighter one.
    hook up 2 wires to your original wiring ground wire and a power wire thats the directionals
    now your choice do you want running lights or additional brake lights?
    if it is running lights you will need to tap into the rear tail light wire for the rear lights
    if brake lights tap into the brake light wire.
    if you want running lights up front you will need to run the extra wire back to the head light relay output wire it is the wire that runs to the high low switch.
    tap into that and the lights will come on with the head light
    Kevin A, Jetfixer and Lightcs1776 like this.
  4. Kevin A
    Kevin A Member
    thanks for all the help guys . I'll let you know how it turns out .
