wiring
Discussion in 'XJ Modifications' started by maxim600, Jun 16, 2008.
  1. maxim600
    maxim600 New Member
    hi i have a 81 yamaha maxim with a 86-88 radian motor and i cant get it to turn over the oil light comes on. it has oil.
    where does the white wire go?
  2. Grynen
    Grynen Member
    Holland Landing
    my bike was doing that. Do you hear a click when you puch the starter button? If you hear the click then give the starter a tap. It sounds like it needs a little TLC. If it is not even clicking then check the solenoid..
    Cheers,
  3. Robert
    Greetings Maxim600. There are a few white wires involved in a Maxim harness, care to narrow it down a bit? It would also be helpful if you could provide a schematic for the Radian.
  4. maxim600
    maxim600 New Member
    there is no click and the wiring is off a working bike i put the solenoids right back on once i got the wiring through the hole at the base of the gas tank.
    the white is on the oil sensor on the bottom of the motor.
  5. FISH
    FISH New Member
    I HAVE BUILT A 1982 XJ 650 CHOPPER NOW I AM AT THE WIRE ING STAGE WIRING IS MY WEAKNESS I HAVE HEARD YOU CAN BREAK THE HARNESS DOWN TO 11 WIRES CAN ANYONE HELP ME WITH A DIAGRAM PLLLEEEAAAASSSSEEEE !!!!!!!!!!!!!!!!!!!!!!!!!!!!
  6. wizard
    Try this, FISH.
