Wrong fuse panel????
Discussion in 'XJ Modifications' started by Harlan, Aug 17, 2013.
  1. Harlan
    Harlan New Member
    West Des Moines, IA
    I ordered a new blade fuse panel from BikeBandit but it does not look like it will work. It is a four fuse set up but only has 4 posts to connect spade connectors and one threaded post. Can I make this work or do I need to order a new unit?
  2. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    You could, in theory.
    In practice, it's easier to get the correct panel.
  3. Harlan
    Harlan New Member
    West Des Moines, IA
    That is what I thought. I will return this one. Any suggestions on a vendor?? A friend recommended BikeBandit but I am a newbie and wonder if there is a better source.
    p.s. I tried to put pics in my post but they were too large too down load.
  4. JPaganel
    Minneapolis
    I know the kind you are talking about. It is a distribution panel with a bus on one side to hook the battery + to. It is for attaching multiple accessories to one feed.
    Len (Chacal) sells a fuse panel.
    I bought mine from a local auto parts store. Look for a 5-fuse panel with side terminals. They are about $10-$12 just about everywhere.
  5. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
  6. Harlan
    Harlan New Member
    West Des Moines, IA
    new fuse panel installed after work tonight. Still no turn signals. The hunt continues.
  7. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    sure the bulbs are good?
    sure wires aren't broken?
  8. slackard
    slackard Active Member
    Earth, Terran System
  9. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    It looks crowded underneath....I prefer the in & outs opposite one another for the fuse panel.....picked mine up at Napa.....only no cover & old style, when it wears out in 10 yrs....just buy another....I will screw to air box & place plastic cover over it....
  10. RickCoMatic
    Fuse Panels should be:
    • Not a Fire Hazard
    • Covered
    • Securely Mounted away from Frame
    • Incapable of being accidentally short-circuited.
    • At the very least ... Water resistant
  11. Harlan
    Harlan New Member
    West Des Moines, IA
    bulbs are good. I will just have to trace it down.
  12. slackard
    Try testing the flasher relay, and continuity of all the wires leading up to it. (haynes manual pg 236, section 22, and the chart on 237)
    Also try disconnecting the cancelling unit and see if the flashers work manually. (you can also test the cancelling unit (haynes manual pg 236, section 23 (photo 23.3 on pg 237)
