WTB Jets
Discussion in 'For Sale, Trade/Swap, Wanted' started by goattank, Jul 22, 2008.
  1. goattank
    goattank New Member
    Elyria, Ohio
    I'm looking for some 118.5 main jets and a 37 pilot jet. I have an 81 maxim xj550 with the mikuni bs28 carbs.
    Thanks,
    Josh
  2. schmuckaholic
    California
    Ask, and Chacal shall deliver:
    MIKUNI FUEL AND AIR JETS:
    Main Fuel Jets:
    ee) OEM and aftermarket Mikuni brass MAIN FUEL JETS, sizes as follows, fits all XJ550, XJ650 (except Turbo), all XJ700-X and XJ750-X, XJ900RK, and XJ1100 models.
    NOTE: stock Mikuni XJ series carbs used the following original main fuel jet sizes:
    #100 1985 XJ700-XN and -XNC models
    #102.5 XJ900RK US & Canada
    #105 1986 XJ700-XS and -XSC models and all XJ750-X
    #107.5 XJ900 1983-84 except USA or Canada
    #112.5 XJ550 all models and XJ1100
    #127.5 XJ650 Turbo carbs for cylinders #1 and #4**
    #132.5 XJ650 Turbo carbs for cylinders #2 and #3**
    *NOTE: there is conflicting information between original and re-printed service manuals and the factory parts manuals concerning the size of the main jets for various Mikuni-equipped models. We have tried to provide the most accurate information available to us above.
    All the other sizes are for "tuning" or re-jetting purposes when changing intakes or exhaust systems.
    HCP6900 OEM Mikuni MAIN FUEL JET #105
    HCP6901 OEM Mikuni MAIN FUEL JET #107.5
    HCP6902 OEM Mikuni MAIN FUEL JET #110
    HCP6903 OEM Mikuni MAIN FUEL JET #112.5
    HCP6904 OEM Mikuni MAIN FUEL JET #115
    HCP6905 OEM Mikuni MAIN FUEL JET #117.5
    HCP6906 OEM Mikuni MAIN FUEL JET #120
    HCP6908 OEM Mikuni MAIN FUEL JET #125
    HCP6909 OEM Mikuni MAIN FUEL JET #127.5
    HCP6910 OEM Mikuni MAIN FUEL JET #130
    HCP6911 OEM Mikuni MAIN FUEL JET #132.5
    HCP6912 OEM Mikuni MAIN FUEL JET #135
    HCP6913 OEM Mikuni MAIN FUEL JET #137.5
    HCP6914 OEM Mikuni MAIN FUEL JET #140
    HCP6915 OEM Mikuni MAIN FUEL JET #142.5
    HCP6916 OEM Mikuni MAIN FUEL JET #145
    HCP6917 OEM Mikuni MAIN FUEL JET #147.5
    HCP6918 OEM Mikuni MAIN FUEL JET #150
    All of the above OEM Mikuni Main Fuel Jets are priced as follows:
    $ 5.50 each
    or
    $ 18.00 per set of 4
    HCP6919 Aftermarket Mikuni MAIN FUEL JET #90
    HCP6920 Aftermarket Mikuni MAIN FUEL JET #95
    HCP6921 Aftermarket Mikuni MAIN FUEL JET #100
    HCP6922 Aftermarket Mikuni MAIN FUEL JET #102.5
    HCP6923 Aftermarket Mikuni MAIN FUEL JET #105
    HCP6924 Aftermarket Mikuni MAIN FUEL JET #107.5
    HCP6925 Aftermarket Mikuni MAIN FUEL JET #110
    HCP6926 Aftermarket Mikuni MAIN FUEL JET #112.5
    HCP6927 Aftermarket Mikuni MAIN FUEL JET #115
    HCP6928 Aftermarket Mikuni MAIN FUEL JET #117.5
    HCP6929 Aftermarket Mikuni MAIN FUEL JET #120
    HCP6930 Aftermarket Mikuni MAIN FUEL JET #122.5
    HCP6931 Aftermarket Mikuni MAIN FUEL JET #125
    HCP6932 Aftermarket Mikuni MAIN FUEL JET #127.5
    HCP6933 Aftermarket Mikuni MAIN FUEL JET #130
    HCP6934 Aftermarket Mikuni MAIN FUEL JET #135
    HCP6936 Aftermarket Mikuni MAIN FUEL JET #140
    HCP6937 Aftermarket Mikuni MAIN FUEL JET #142.5
    HCP6938 Aftermarket Mikuni MAIN FUEL JET #145
    HCP6939 Aftermarket Mikuni MAIN FUEL JET #147.5
    HCP6940 Aftermarket Mikuni MAIN FUEL JET #150
    HCP6941 Aftermarket Mikuni MAIN FUEL JET #152.5
    HCP6942 Aftermarket Mikuni MAIN FUEL JET #155
    HCP6943 Aftermarket Mikuni MAIN FUEL JET #157.5
    HCP6944 Aftermarket Mikuni MAIN FUEL JET #160
    HCP6945 Aftermarket Mikuni MAIN FUEL JET #165
    HCP6946 Aftermarket Mikuni MAIN FUEL JET #170
    HCP6947 Aftermarket Mikuni MAIN FUEL JET #175
    HCP6948 Aftermarket Mikuni MAIN FUEL JET #180
    All of the above Aftermarket Mikuni Main Fuel Jets are priced as follows:
    $ 2.50 each
    or
    $ 9.75 per set of 4
    Main Air Jets:
    Alas, the Mikuni BSxx series carbs used on XJ models---unlike their cousins the Hitachi HSCxx series carbs---did not have replacable main jets. The main air jets on these models are in the carb throat, facing the airbox, and are a small, brass pressed-in tube that is non replacable, and which we suggest you do NOT try to modify by drilling or enlarging.
    And just in case anyone is wondering, here are the sizes of these non-removale main air jets in the various models:
    #45: XJ900RK
    #70: XJ550 all models and XJ650 Turbo models.
    #120: XJ700-X all models and XJ750-X all models*
    #140: XJ1100 models*
    NOTE: we believe that the #120 and #140 sizes listed in the service manuals (from where the above information was gathered) may be incorrect, as these are gigantic sizes for main air jets. But since you can't replace them anyway, I suppose that it doesn't really matter........
    Pilot Fuel Jets:
    ef) OEM and aftermarket Mikuni brass PILOT FUEL JETS, sizes as follows, fits all XJ550, XJ650 (except Turbo), all XJ700-X and XJ750-X, XJ900RK, and XJ1100 models.
    NOTE: stock Mikuni XJ series carbs used the following original pilot fuel jet sizes:
    #32.5 XJ650LK Turbo (1983)
    #35 XJ550 all models, XJ650LJ Turbo (1982), and XJ700-X all models
    #37.5 XJ750-X and XJ900RK USA & Canada only
    #40 XJ900 1983-84 except USA or Canada
    #47.5 XJ1100
    HCP5223 OEM Mikuni PILOT FUEL JET #32.5
    $ 15.00 each
    or
    $ 55.00 set of 4
    HCP5183 OEM Mikuni PILOT FUEL JET #35
    $ 15.00 each
    or
    $ 55.00 set of 4
    HCP6890 OEM Mikuni PILOT FUEL JET #37.5
    $ 14.00 each
    or
    $ 51.00 set of 4
    HCP6889 OEM Mikuni PILOT FUEL JET #47.5
    $ 16.50 each
    or
    $ 59.00 set of 4
    HCP6949 Aftermarket Mikuni PILOT FUEL JET #30
    HCP6950 Aftermarket Mikuni PILOT FUEL JET #32.5
    HCP6951 Aftermarket Mikuni PILOT FUEL JET #35
    HCP6952 Aftermarket Mikuni PILOT FUEL JET #37.5
    HCP6953 Aftermarket Mikuni PILOT FUEL JET #40
    HCP6954 Aftermarket Mikuni PILOT FUEL JET #42.5
    HCP6955 Aftermarket Mikuni PILOT FUEL JET #45
    HCP6956 Aftermarket Mikuni PILOT FUEL JET #47.5
    HCP6957 Aftermarket Mikuni PILOT FUEL JET #50
    HCP6958 Aftermarket Mikuni PILOT FUEL JET #52.5
    HCP6959 Aftermarket Mikuni PILOT FUEL JET #55
    All of the above Aftermarket Mikuni Pilot Fuel Jets are priced as follows:
    $ 4.50 each
    or
    $ 14.00 per set of 4
    Pilot Air Jets:
    Pilot air jets on the Mikuni BSxx series carbs are replacable and are located under the diaphram cover on all XJ550 models, and XJ650 Turbo models, and in the carb throat, facing the airbox, on all XJ700-X, XJ750-X, XJ900RK, and XJ1100 models.
    ef) OEM and aftermarket Mikuni brass PILOT AIR JETS, sizes as follows, fits all XJ550, XJ650 (except Turbo), all XJ700-X and XJ750-X, XJ900RK, and XJ1100 models.
    NOTE: stock Mikuni XJ series carbs used the following original pilot air jet sizes:
    #120 XJ750-X models
    #140 XJ700-X and XJ750-X models
    #160 XJ900RK all models
    #165 XJ550 Maxim models
    #170 XJ550 Seca models, XJ650 Turbo, and XJ1100
    HCP5218 OEM Mikuni PILOT AIR JET #155
    $ 8.50 each
    or
    $ 32.00 set of 4
    HCP6892 OEM Mikuni PILOT AIR JET #160
    $ 8.00 each
    or
    $ 302.00 set of 4
    HCP5206 OEM Mikuni PILOT AIR JET #165
    $ 6.50 each
    or
    $ 24.00 set of 4
    HCP5171 OEM Mikuni PILOT AIR JET #170
    $ 8.00 each
    or
    $ 30.00 set of 4
    HCP6960 Aftermarket Mikuni PILOT AIR JET #110
    HCP6961 Aftermarket Mikuni PILOT AIR JET #112.5
    HCP6962 Aftermarket Mikuni PILOT AIR JET #115
    HCP6963 Aftermarket Mikuni PILOT AIR JET #117.5
    HCP6964 Aftermarket Mikuni PILOT AIR JET #120
    HCP6965 Aftermarket Mikuni PILOT AIR JET #122.5
    HCP6966 Aftermarket Mikuni PILOT AIR JET #125
    HCP6967 Aftermarket Mikuni PILOT AIR JET #130
    HCP6968 Aftermarket Mikuni PILOT AIR JET #135
    HCP6969 Aftermarket Mikuni PILOT AIR JET #137.5
    HCP6970 Aftermarket Mikuni PILOT AIR JET #140
    HCP6971 Aftermarket Mikuni PILOT AIR JET #142.5
    HCP6972 Aftermarket Mikuni PILOT AIR JET #145
    HCP6973 Aftermarket Mikuni PILOT AIR JET #147.5
    HCP6974 Aftermarket Mikuni PILOT AIR JET #150
    All of the above Aftermarket Mikuni Pilot Air Jets are priced as follows:
    $ 2.50 each
    or
    $ 9.50 per set of 4
    Talk to Chacal for ordering.
    Why so big? You putting on pods or something? He's got something to say about that, too... ;)
