WTB Jets
Discussion in 'For Sale, Trade/Swap, Wanted' started by xdarrickx, Apr 28, 2008.
  1. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    Carb jets for an 82 XJ650 Maxim.
    Size 144 main and 42 pilot. any help would be appreciated.
  2. Old-Grunt
    Old-Grunt Member
    that would be a huge main???did you mean 114?
  3. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    yeah I did... I had XS carbs on the brain. I just ordered some for another build. I do mean 114 for the main. Numbers are easily confusing.
  4. chacal
    Here they are!:
    Main & Pilot Fuel Jets:
    ee) Aftermarket Hitachi brass MAIN FUEL JETS, sizes as follows, fits all XJ650 (except Turbo), all XJ750, and all XJ700 (exc. "X") models.
    NOTE: stock Hitachi XJ series carbs used the following original sizes:
    #106 (XJ 750 Seca, 1984 only)
    #107 (XJ700 non-X)
    #110 (650 models)
    #120 (all 750 models except 1984 XJ750 Seca)
    All the other sizes are for "tuning" or re-jetting purposes when changing intakes or exhaust systems.
    HCP6316 aftermarket brass #106 MAIN FUEL JET (stock size for '84 XJ750 Seca)
    HCP6317 aftermarket brass #107 MAIN FUEL JET (stock size for XJ700 non-X)
    HCP6318 aftermarket brass #108 MAIN FUEL JET
    HCP6319 aftermarket brass #109 MAIN FUEL JET
    Any size jet from above, HCP6316 - HCP6319:
    $ 6.00 each
    or
    $ 21.00 for a set of 4 (mix-and-match any of the above sizes okay)
    HCP873 aftermarket brass #110 MAIN FUEL JET (stock size for XJ650)
    HCP874 aftermarket brass #112 MAIN FUEL JET
    HCP875 aftermarket brass #116 MAIN FUEL JET
    HCP876 aftermarket brass #118 MAIN FUEL JET
    HCP877 aftermarket brass #120 MAIN FUEL JET (stock size for XJ750)
    HCP878 aftermarket brass #122 MAIN FUEL JET
    HCP879 aftermarket brass #124 MAIN FUEL JET
    HCP880 aftermarket brass #126 MAIN FUEL JET
    HCP881 aftermarket brass #128 MAIN FUEL JET
    HCP882 aftermarket brass #130 MAIN FUEL JET
    HCP883 aftermarket brass #132 MAIN FUEL JET
    HCP884 aftermarket brass #134 MAIN FUEL JET
    Any size jet from above, HCP873 - HCP884:
    $ 3.25 each
    or
    $ 11.00 for a set of 4 (mix-and-match any of the above sizes okay)
    xx3) Reproduction Hitachi main fuel jet SPACER WASHER, round flat copper washer goes under the head of the main fuel jet. Perfectly replaces missing or bowed originals.
    HCP12 Hitachi carbs main fuel jet spacer washer, each:
    $ 6.00
    HCP12SET4 Hitachi carbs main fuel jet spacer washer, set of 4:
    $ 19.00
    ff) Aftermarket Hitachi PILOT FUEL JET, sizes as follows, fits all XJ650 (except Turbo), all XJ750, and all XJ700 (exc. "X") models.
    #36.5 all XJ700 non-X models.
    #40 all XJ650 Maxim, Midnight Maxin, and Seca (RK) models, and all XJ750 models.
    #43: all 1984 XJ750 Seca and Euro/UK XJ750 models.
    The #41, #42, and #43 sizes are for "tuning" or re-jetting purposes when changing intakes or exhaust systems.
    HCP885 aftermarket brass #40 PILOT FUEL JET
    HCP886 aftermarket brass #41 PILOT FUEL JET
    Either size jet above, HCP885 or HCP886:
    $ 3.25 each
    or
    $ 11.00 for a set of 4 (mix-and-match #40 or #41 sizes okay)
    HCP6326 aftermarket brass #42 PILOT FUEL JET
    HCP6320 aftermarket brass #43 PILOT FUEL JET
    Either size jet above, HCP6326 or HCP6320:
    $ 5.25 each
    or
    $ 19.00 for a set of 4 (mix-and-match #42 or #43 sizes okay)
