WTB/WTT: Valve shim for XJ550 Maxim - 2.75mm
Discussion in 'For Sale, Trade/Swap, Wanted' started by RickDick80, Aug 4, 2008.
  1. RickDick80
    RickDick80 Member
    Chicagoland, Ill-Annoy
    Hi all, I'm doing the valve shim thing on my Maxim 550, and I need one 2.75mm shim to get the job done. If you have one for sale that isn't rusty, cool. If you have one that's lightly surface rusted, I'd like to see a pic. And if you want to trade, I have available two 2.80 shims and a 2.90 shim.
    PM me if interested!
    -Rick
  2. schmuckaholic
    California
    You've come to the right place. Chacal has all the valve shims you could possibly want.
    VALVETRAIN PARTS:
    z) OEM Yamaha VALVE SHIMS, all sizes 2.00 through 3.20, fits all Yamaha XJ models EXCEPT XJ700-X models.
    $11.50 each
    or
    any 5 shims (any mix of sizes) for $55.00
    HCP248A OEM Yamaha Valve Shim 2.00
    HCP248B OEM Yamaha Valve Shim 2.05
    HCP248C OEM Yamaha Valve Shim 2.10
    HCP248D OEM Yamaha Valve Shim 2.15
    HCP248E OEM Yamaha Valve Shim 2.20
    HCP248F OEM Yamaha Valve Shim 2.25
    HCP248G OEM Yamaha Valve Shim 2.30
    HCP248H OEM Yamaha Valve Shim 2.35
    HCP248J OEM Yamaha Valve Shim 2.40
    HCP248K OEM Yamaha Valve Shim 2.45
    HCP248L OEM Yamaha Valve Shim 2.50
    HCP248M OEM Yamaha Valve Shim 2.55
    HCP248N OEM Yamaha Valve Shim 2.60
    HCP248P OEM Yamaha Valve Shim 2.65
    HCP248Q OEM Yamaha Valve Shim 2.70
    HCP248R OEM Yamaha Valve Shim 2.75
    HCP248S OEM Yamaha Valve Shim 2.80
    HCP248T OEM Yamaha Valve Shim 2.85
    HCP248U OEM Yamaha Valve Shim 2.90
    HCP248V OEM Yamaha Valve Shim 2.95
    HCP248W OEM Yamaha Valve Shim 3.00
    HCP248X OEM Yamaha Valve Shim 3.05
    HCP248Y OEM Yamaha Valve Shim 3.10
    HCP248Z OEM Yamaha Valve Shim 3.15
    HCP248AA OEM Yamaha Valve Shim 3.20
    aa) Aftermarket Yamaha VALVE SHIMS, all sizes 2.00 thru 3.10, these are the correct 29mm diameter shims with 90-degree squared edges, and are NOT Suzuki shims. Fits all Yamaha XJ models EXCEPT XJ700-X models.
    $ 7.50 each
    or
    any 5 shims (any mix of sizes) for $ 35.00
    HCP788 Aftermarket Yamaha Valve Shim 2.00
    HCP789 Aftermarket Yamaha Valve Shim 2.05
    HCP790 Aftermarket Yamaha Valve Shim 2.10
    HCP791 Aftermarket Yamaha Valve Shim 2.15
    HCP792 Aftermarket Yamaha Valve Shim 2.20
    HCP793 Aftermarket Yamaha Valve Shim 2.25
    HCP794 Aftermarket Yamaha Valve Shim 2.30
    HCP795 Aftermarket Yamaha Valve Shim 2.35
    HCP796 Aftermarket Yamaha Valve Shim 2.40
    HCP797 Aftermarket Yamaha Valve Shim 2.45
    HCP798 Aftermarket Yamaha Valve Shim 2.50
    HCP799 Aftermarket Yamaha Valve Shim 2.55
    HCP800 Aftermarket Yamaha Valve Shim 2.60
    HCP801 Aftermarket Yamaha Valve Shim 2.65
    HCP802 Aftermarket Yamaha Valve Shim 2.70
    HCP803 Aftermarket Yamaha Valve Shim 2.75
    HCP804 Aftermarket Yamaha Valve Shim 2.80
    HCP805 Aftermarket Yamaha Valve Shim 2.85
    HCP806 Aftermarket Yamaha Valve Shim 2.90
    HCP807 Aftermarket Yamaha Valve Shim 2.95
    HCP808 Aftermarket Yamaha Valve Shim 3.00
    HCP809 Aftermarket Yamaha Valve Shim 3.05
    HCP810 Aftermarket Yamaha Valve Shim 3.10
  3. chacal
    AND that all-important valve shim removal tool:
    bb) Valve Shim Tool, correct reproduction of the original bucket retainer tool #90890-01245-00, required when changing valve shims. For all Yamaha XJ models EXCEPT XJ700-X models.
    HCP247A Aftermarket Valve Shim Tool
    $ 15.00
