WTB: XJ650 tank
Discussion in 'For Sale, Trade/Swap, Wanted' started by tombo, Nov 19, 2015.
  1. tombo
    tombo Member
    San Francisco, CA
    I'd like one as dent and rust free as possible. If you've got one, let's talk
  2. Busted Knuckles
    Busted Knuckles Member
    North
    Still looking for a tank?
  3. tombo
    tombo Member
    San Francisco, CA
    You got one you are willing to part with?
  4. Busted Knuckles
    North
    Yep. I started building an 82 Seca 650 to discover an unsalvagable motor. Going to start the process of parting it out tonight. I'll get some pics tonight.
  5. tombo
    tombo Member
    San Francisco, CA
    Doh! I need one for a maxim
  6. hogfiddles
    Why not get a 750 maxim tank? It is a direct bolt-on upgrade... Giving a nicer shape and contour line to the bike and also gives you another gal or so of fuel
  7. tombo
    tombo Member
    San Francisco, CA
    ^ I'd love one, but seems like unobtanium. You got one for me?
  8. hogfiddles
    Maybe--- I'll look to see.....
  9. tombo
    tombo Member
    San Francisco, CA
    That'd be awesome thanks!
  10. hogfiddles
    I'm at a conference for the weekend, but remind me on Sunday or Monday when i get home, and I'll dig through
  11. tombo
    tombo Member
    San Francisco, CA
    It's sunday, Figured I'd check in with you. No big rush, but let me know what you find. :)
  12. hogfiddles
    Still traveling, home later
  13. tombo
    tombo Member
    San Francisco, CA
    Hogfiddles -
    Hope your travels were well, checking in on your possible tank?
  14. hogfiddles
    I have:
    one that had dents, and needs to be cleaned inside
    One that has no key, so I have to get that open first to see about condition
  15. tombo
    tombo Member
    San Francisco, CA
    Pm sent
  16. af226
    af226 Member
    Kingston, ON
    hogfiddles....I'm looking to upgrade as well. I have been looking locally for a while and have only found one that was to far gone. Does the gas cap and petcock transfer over from my 650 tank? I know I would have to plug the fuel sending unit hole. Reason is that I just picked up a new ignition and gas cap with matching key:)
  17. Dusty53
    Dusty53 New Member
    I recently purchased a XJ550 seca tank with a locked fuel cap and was able to pick the lock within 15 minutes just had to keep pressure on the key slot (as if to turn it clockwise) and using a "J" curved pick, worked the 5 pins from the bottom up. Once you've done it a few times you'll find it's really easy, I also unlocked an XJ900 tank that I've had lying around for over two years
  18. hogfiddles
    The 750 maxim tank is a DIRECT swap.
    The cap swaps right over, as does the petcock.
    For the sending unit..... They made some tanks with it, and some without it. If you have a tank with it, just wrap the pigtail up and tuck it out of the way. If your tank is missing it the you'll need to make a block-off plate. If your tank didnt come with one, you don't need to do anything other than bolt it on and go ride.
    I see you're in Canada.... It's risky enough here to ship a gas tank-- I'm not going to even think about shipping across a border. Ya wanna drive to Utica, NY?
  19. k-moe
    If you do get a 750 tank with a sending unit you might want to make a fuel gauge for it.
  20. af226
    af226 Member
    Kingston, ON
    The sad part is that I go to Watertown and out around Old Forge regularly in the summer. Utica is not that far away, I may PM you in the spring and see if you still have a 750 tank that is in decent shape:)
    af226
  21. hogfiddles
    Yeah if you come to Watertown a lot… That's only an hour maybe a little bit more from me-I'm sure we could probably arrange something.
    If you don't mind waiting till the spring or summer, let's see what we can do.
