xj 650 cylinder wall gouges question
Discussion in 'XJ Modifications' started by wreck1819, Apr 24, 2013.
  1. wreck1819
    wreck1819 New Member
    Texas
    So I picked up a 1981 xj 650 h for a project I planned on turning into a cafe racer. After getting into the engine I noticed there was some surface rust on some components but as I was about to start honing the cylinder walls i noticed some gouges on one of them.
    My question, If I hone it a bit will it still be run-able. Or is it shot in this condition and need to be bored to the next .25 spec. Keep in mind I'm a broke as sh!t college student paying hospital bills, so my budget is tiny to say the least...
    Thanks John
  2. wizard
    Hi John, honing will not help, take the block to a machine shop, they can measure the depth of the grooves, they look to deep to rebore. Maybe you can find a cheap, low mileage block.
  3. Orange-n-Black
    Memphis Area
    Search ebay for some jugs and switch them out along with some new rings.
  4. 750E-II_29Rbloke
    South Cheshire, UK
    They're nasty :( they look at *least* half a mil deep from the pic (so would need minimum 1mm rebore & may still not go)
    I'd look for a set of barrels/jugs as suggested. I'm wondering how it happened, broken rings? looks off axis to be a loose pin...
  5. wreck1819
    Texas
    I have no idea how it had happened. The rings are fine the pins are fine i cant seem to find anything wrong. this is cylinder three, cylinder two was the one I imagined having problems with since it was rusted up seizing the engine, but it cleaned up fine. Damn...
  6. k-moe
    My WAG: some PO replaced the rings after experiencing a ring failure on that cylinder (cause of the gouging) and figured that he'd just live with the oil consumption for the time being.
    WAG #2: A PO who was "good with bikes" attempted to "drill out" the crankshaft by way of the spark plug hole.
  7. 750E-II_29Rbloke
    South Cheshire, UK
    What stevo sold his bike on already? :D hahaha sorry bit of an in-joke...
    Actually, my money is now on somebody was changing a shim without the proper tools and "lost" the end of their wire they were holding a valve with... several times... and figured "what the heck it's only copper, it'll just squash out the way" :roll:
