XJ 650 Valve clearance adjustment (Tools?)
Discussion in 'XJ Technical Chat' started by fearxunleashed, Jun 19, 2012.
  1. fearxunleashed
    fearxunleashed Member
    So i'm in the process of cleaning up my XJ 650, it hasn't been running at all / properly and most likely is a carb issue, but my brother and I started at the beginning and are working on the valve clearances.
    For cylinder 1-4 exhaust, they all measured roughly the same, at .203mm.
    Cylinder 1 intake : .152mm
    Cylinder 2 intake: .127mm
    Cylinder 3 intake: .127mm
    Cylinder 4 intake: .076mm
    So i'm assuming we need to make adjustments on cylinder 1 intake, and cylinder 4 intake to match 2 and 3?
    Now the question is, how do you remove the shim? Is there a special tool we need to buy to make the adjustments and pop the shim out, and then purchase another?
  2. wwj750
    wwj750 Member
    central minnesota
    There is a special tool. Part #HPC247 @ XJ4ever at the top of the page. $15.00. Some guys find it a little tricky to use, but once you get the hang of it, it works like a charm. One member posted just today that he had to modify his a bit to get it to work, but I think this is an exception.
    There is another method also, but I have no experience with that. Get the tool.
  3. supertown07
    supertown07 New Member
    Rambling; From Garfield Heights, Ohio
    i used the zip tie method and it worked very easily with no problems. plus it costs less haha
  4. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Exhaust 1-4 are ok
    Intake 1-3 are ok
    Intake on 4 needs to go down one shim size.
