XJ 665 Hellboy is now Finished
Discussion in 'XJ Modifications' started by misterlee, Sep 15, 2006.
  1. misterlee
    misterlee New Member
    philippines
    finally my latest project is succesfully finished. An old ugly XJ 650 is now a new pretty XJ 665 ( its still a 650 but 665 sounds mmmmm special) Things i changed on the bike: From single disk brake to double disk brake including the forks from an XJ 650 euro version, added oil cooler, squeezed a fat 160 tire into the rear, custom paintjob (myself), crashbars from a 750 virago, brand new BMW consoles, Bosch Horns, 4x POSH carbon fiber covered airfilters, custom seat cover, Koni Shock absorbers (springs had to be powdercoated) Harley Davidson Taillight, and a few neon light add ons for the evening. Signal lights could not be installed yet due to very expensive relay system (see BMW console) its the same on Harleys and BMW's , touch button system. nevertheless, the bikes' performance is still quite good, im surprised with the very little difference the 160 rear tire made, if you shake the steering wheel very hard you'll notice its not as stable as with the 130, but what the heck, to be honest its a showbike, im riding it for just short and slow distances here in the Philippines. im happy to hear any comments, questions, and suggestions from you guys. Thanks! Check out the gallery for more pictures
    POWER TO THE XJ!
  2. woolsac
    woolsac Member
    Sparta, NJ
    sweeters! :D
  3. Joel07
    Joel07 Member
    Durham, NC, USA
    Wow, nice job!! I like the new switches and controls, gives the bike a much more modern look. So are the pipes on the left side just fakies? Either way, looks cool, would have been even cooler had you been able to hook both sides up. :lol:
  4. HooNz
    HooNz Member
    looks ok , i was nearly going to ask why is that bar on the back so leaning backwards , then i saw the roof....boing!!!!
  5. Robert
    Hey, I nearly asked the same question! Doh! I'm impressed with the exhaust silencers, they really add a nice touch. The 160 looks really aggressive. Any trouble with contact?
  6. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    Yea that works! But I;m curious like Robert about how you cleared the 160.
  7. misterlee
    philippines
    well, they're not fakies, the exhaust pipes are built 4 in 4, so one pipe for each piston, i removed the Y piece below. it makes a realy nice sound.... i guess i'l lose a few horses, but i dont realy need all here in the PH. Thanks man!
  8. RickCoMatic
    Bravo! Bravo!
    What a looker! Your skills are well displayed. I marvel, not only at your fabulous paint job; but also at your custom mods that really look GREAT!
    As one who does a little bit of Custom Crafting, myself ... there's just a few other things I'd like to recommend for your consideration.
    Stainless steel fasteners all-over ... including the complete carb-kit. I got a Stainless Carb Kit -- all stainless cap screws -- off eBay for 11-Bucks!
    Custom rear foot-pegs replacing the antique original's ... which don't seem to match the decor. (If the bike's really going to be a flashy Custom Show Bike -- Think about putting some "Slider's" on ... replacing the footpegs. They'll add an additional Custom-built by you touch.)
    Polish the outboard carb fuel bowls until you can look at 'em and see if you need a shave!! : )
    Then, get two ... very well endowed Blondes, wearing some designer, next-to-nothing swim wear, to point and smile at your bike when you show it!!!
  9. SnoSheriff
    MB, CAN
    That is one good looking ride you got there. How did you do the red accents?
  10. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    Very curious as to how you fittted the crashbars; any mooding necessary? And are they standard (meaning still avilable)?
  11. misterlee
    philippines
    which accent do you mean? ok, the handle bars, rear springs, and sidestand were powdercoated. the red lines on the seat were made out of the same material as the black seat, and thin rope is inside to give it a little volume. the red flames were airbrushed. :)
  12. misterlee
    philippines
    they are standard virago 750 (80-85 i guess) crashbars. on 650's there are two holes in front where you normaly attach the horn, there i attached an angle bar across so as to attach one end of the crash bars. the lower end i was able to attach to an existing bolt.. i can send you detailed pics if you want
  13. misterlee
    philippines
    a 9mm spacer took care of the contact problem. (see pics in my gallery) there's a disjunction from the center but not much difference in handling. maybe not recommendable for high speeds. the frame had to be modified as well, but not much. 8) .
  14. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    That´d be great, Misterlee :D
  15. OU812didntU
    OU812didntU Member
    one of a kind!!! you can certainly tell you put allot of time, money, and elbow grease into that beauty. Nice job
  16. xjchoppa
    xjchoppa Member
    Oklahoma City, OK
    sweet bike now that is custom..
  17. robista361
    robista361 Member
    winslow, Maine
    yup... like I said before...your bike kicks ass!
  18. XJJeff
    XJJeff Member
    <a href="http://maps.google.com/maps?q=88.583765+4
    Mr.Lee
    How did you manage the 160 tire on there? I'm assuming thats a shaft drive. I have a 1980 XJ650 Maxim and the best I can do w/out rubbing is a 130.130/90-16 tire is on it now Please tell me your secret so I can go wider.
  19. Deathjester
    Deathjester New Member
    Vancouver, Wa.
    Thats sweet.
    The reason why I looked and found this board is because I want to change from a single brake to a dual. You got info on that mod to help me out?? Ive got an 82 maxim 650.
  20. misterlee
    philippines
    The red flames on the tank, sidecover, front/back fender and frame were done by a simple airbrush. Take note that i pre-airbrushed it with white so the red color would be stronger. The red lines on the seat were done by a simple upholstery in town... the handlebars, sidestand, and springs were powdercoated
  21. killer27574
    killer27574 New Member
    I really like the design of your bike looks like you spent alot of time on your xj awesome!!
  22. IndyMaxim
    IndyMaxim Member
    Indianapolis
    Whatever man, he's in the Philippines... I definitely wouldn't mind seeing some of the beautiful local talent pictured with the bike... Or without it :)
