xj identification
Discussion in 'XJ Technical Chat' started by Gearhead76, Feb 10, 2007.
  1. Gearhead76
    Gearhead76 Member
    Appleton WI
    Hi new to site, I just picked up a seca 750 yesterday, and just trying to find out what I accually got, Not sure on year or model. rh j or what,
    The frame says 6/82 and the side cover says 83 emisions, so not sure what year.
    the frame numbers are jya5g200 da150925
    the engine numbers are 5g2 150p25
    If anyone could help that would be great, just trying to figure out which wiring diagram to use in the haynes manual. tring to figure out the head light, and fog light, it has a fairing and it worked once and that was it, I had to remove the fairing to pull ing, switch so I could get a key made
    Thanks in advance for the help
    Gearhead76
    I'll try to get a pic for you guys
  2. ridz
    ridz Member
    Ride hard and live free!
    i dont think you need that whole number. some thing about protecting your personal info. im not sure but i think it is the first 4 or last 4 numbers. sorry i could nt help more. some body will come along who knows.good luck.
  3. WeAreZilla
    WeAreZilla Member
    Yellow Submarine
    I found conflicting information on model code "5G2", which was purportedly used for '81 '82 and '83 model years. But I believe the "150" in your numbers gives it away.
    1983 Seca XJ750RK
    Have fun!
    Z
    From my sources:
    XJ750RH 5G2-000101 5G2 1981
    XJ750RJ 5G2-100101 5G2 1982
    XJ750RK 5G2-150101 5G2 1983
  4. Gearhead76
    Gearhead76 Member
    Appleton WI
    Thanks for the help
