XJ1100 - 2nd oversize big bore - headgasket
Discussion in 'XJ Modifications' started by kjohnson, Aug 24, 2012.
  1. kjohnson
    kjohnson Member
    Wetaskiwin, AB, Canada
    Does anyone know at about what point the factory head gasket can't be uses with over sized pistons? The second oversize I have fit through the steel ring, but there is very little clearance (~.75mm). Should I look into a different head gasket or is this going to work? The service manual doesn't really say anything about the matter.
    TIA,
