Xj550 engine mods
Discussion in 'XJ Modifications' started by hanner73, Jun 18, 2016.
  1. hanner73
    hanner73 New Member
    Illinois
    hi every1 I'm new and tried to search before asking, I know some may get upset when u ask with out trying first. But with 275 threads sorry not reading them all so forgive me if this has been covered. Looking for info on engine mods for xj550. Seen a Video of a cafe version and didn't sound stock so are there cam, choices , heads , valves ect. And who has done them and what's your parts source if so. Any info is appreciated.
    if it is a maxim motor you can put a seca 550 cams set (head swap) and rejet to seca carb specs
    which can be found here
    http://xjbikes.wikidot.com/carb-specs
    basic carb differences in pilot air jet and slide needles.
    they did make adjustable cam kits where the sprocket was adjustable.
    air shifters are out there. convert to full led lighting system will add a little to the bike.
    you could polish the intake exhaust ports go to oversized pistons.
    my advice would be to buy a bigger bike if you are not happy with the performance of a 550
    13 second 1/4 mile is not to shabby red line in 20 seconds.
    move up in tire height for more top end. if it is a maxim put a seca rim on the back
    we have a member who converted to a 600 jug head set up
    you can also wrap the exhaust it will also give you a little more hp
    go to electronic tach remove the drag from motor from tach cable close off port
  3. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    The 750 Seca does the 1/4 mile in 11 seconds. It might be easier to swap bikes, cuz the engine swap won't happen. Shaft vs. chain drive. Only the 550s have the chain.
  4. XJ550H
    yup thats why I said
    "my advice would be to buy a bigger bike if you are not happy with the performance of a 550"
    would cost less in the long run:):) and I do need something to keep the others company:rolleyes:
    Jetfixer likes this.
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    I'm half-way through an engine build that will use 600 (58.5mm) pistons and an FJ/XJ600 head on a 550 bottom end. Kickaha on here has already done this. It ups the cc to about 556 from 528 and you get bigger valves. Not sure on how you would carburate in yet but that's all part of the fun right ?
  6. k-moe
    He can swap cams without pulling the head. Carbs will need to be rejetted to take advantage of the cam swap.
  7. Kickaha
    New Zealand
    I only used the pistons on the first one, head and pistons are for the next one, might be using bigger pistons too if we can find something off the shelf
    I used stock jetting with the first one and it ran mint but nothing else other than the pistons was done to it, bike two I have a set of 26mm Keihin CR carbs for
  8. hanner73
    hanner73 New Member
    Illinois
    Thanks it's a great running bike and in good shape, yes it is a maxim. It's a 550 so it is what it is just a gear head at heart and no matter what u have there's always tricks to get a little more
  9. darren ditmar
    darren ditmar Member
    eugene oregon
    would the radian cams work in the 550??
  10. darren ditmar
    eugene oregon
  11. a100man
    Bedford, UK
    Interesting. Note that the Radian and FJ/FZ 600 cams will not have the tacho drive on the exhaust cam..
  12. Ravivos
    Ravivos New Member
    Israel
    Regarding buying a bigger bike, not sure i agree with that.
    the xj550 is a great little bike, light and agile.
    personally, i converted mine to run Microsquirt for management (Ignition and Fuel) and plan on turboing it with a small turbo for a more "linear" feel.
    i know, its not easy to modify an engine to run engine management system, but if you have the fabrication skills, go for it.
    as i see it -
    58.5mm pistons,
    32mm throttle bodies.
    4-2-1 stainless exhaust system (soon to be modified for boost)
    other than that, i would leave the engine modifications for last.
    on my bike, i have an R6 front suspension that i manage to get the original 19" wheel on, with twin 320mm floating disk brakes,
    Rear suspension went through a complete rebuild and are great.
    remove some weight from the bike, treat it well , and you will enjoy it.
  13. MattiThundrrr
    But will removing weight get you 2 seconds in a quarter mile? If so, I'm going on a diet! Easiest weight to remove from my bike is that pesky spare tire.
    Jetfixer and hanner73 like this.
  14. k-moe
    Actually lightness is a big contributing factor to performance. The first-year GSXR750 was revolutionary not because of the engine, but because of how much lighter it was compared to the competition, and the competition took note.
  15. MattiThundrrr
    I know lightness is a big factor. Colin Chapman of Lotus fame said "The easiest thing to add to a machine to make it faster is lightness." In car drag racing, the claim is for every 100 lbs you lose, you gain a tenth of a second. I feel that to gain the difference from 550 to 750 (13 seconds to 11 seconds) you'd have to trim quite a bit. That's why I say if more speed is what he's searching for, more power will provide easier gains. Not sure what 1/4 mile times are for 900 or 1100, but if anyone wants to lend me theirs, I'll find out! Anyone? I'll give you a million hugs!
  16. XJ550H
    it is the collective of what he can do that will shave the 2 seconds, seca cams and carbs. = .5
    convert to led all around light weight housings for the directionals and tail light less drag on alt.
    switch on head light to turn it off
    mac 4 to 1 exhaust is 16 lbs, oem exhaust 29 lbs
    shop around for tires by weight. go to plastic seca chain guard seca plastic rear fender. cut the front fender down. cut the seat in half,loose the chain box, tool tray.
    smaller battery.
    strip it like old school bobber
    taller rear tire will add top end ( but if it top end you want bigger bike)
  17. a100man
    Bedford, UK
    Have we seen a picture of this middle-eastern masterpiece yet ? If not I would like !
    Cheers
    James
    hanner73 likes this.
  18. hanner73
    hanner73 New Member
    Illinois
    I will be posting pics soon, on vacation at the moment
  19. hanner73
    hanner73 New Member
    Illinois
    Ok I have a lot of great ideas, but I ask this: I ordered the Mac 4:1 exhaust, it has removable silencer, if I remove it and get a different air breather I know it should be jetted. Will the specs for the seca 650 jetting shown in the link work for these two mods?
  20. a100man
    Bedford, UK
    Of course your's too but also the Microsquirted one in Israel..
  21. XJ550H
    no read this link in it you will find a formula for rejetting based on the mods you do BE aware it is just a place to start
    The Information Overload Hour
    if you go to the jetting sales company they will sell you a kit they think will work for you.
    read this this is what you will have to go through to tune carbs for your bike
    http://www.factorypro.com/tech_tuning_procedures/tuning_carbtune,CV,high_rpm_engines.html
    read this too it may help you
    http://www.dansmc.com/carbs2.htm
    before you start to modify the bike make sure it is running correctly
  22. hanner73
    hanner73 New Member
    Illinois
    Bike is in great shape and runs perfect as is. Fantastic read on carb adjustment. I'm no carb guru but when I looked at ur other link with the carb specs it shows a main jet and pilot air/fuel jet. The tuneing link never mentioned anything about the pilot jets?
  23. Ravivos
    Ravivos New Member
    Israel
    well, in order to not hijack this thread, ill just leave a couple of pics .
    still a long way to go, need to conclude the wiring and bodywork.
    but the engine runs perfectly, managed by MS.
    different front with new brakes on original wheels.
    4-2-1 SS exhaust system, designed and built for performance.
    a100man and Reed7742 like this.
  24. Reed7742
    Reed7742 Member
    Mission Ks
    More please :D
  25. a100man
    Bedford, UK
    Better start a new thread - we need details !
    Reed7742 likes this.
  26. XJ550H
    pilot jet is idle to 2500-3500 rpm adjusted with mixture screw using a color tune or by pipe temp or by ear. barely comes into the picture to go through plug chops when you can color tune it
    if you need to change it the color tune will tell you
    edit on a 550in first gear 10 mph =2500 rpm 15 mph=3500 rpm which is all happening in a few yards
    trying to go slow below a normal start from light or stop sign, would be more like moving up to stop sign after the person in front of you went.
    my understanding of the pilot circuit it is to idle bike and make it pass epa emissions testing of the era
  27. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Ok peoples, I have some Spec II 5730 grind cams. Problem is no one makes valve springs for them any more. Everyone says, " send us the head and cams AND $700 we will make some for you. Does any one have any ideas? sat.jpg
  28. Kickaha
    New Zealand
    Whats so special about the cams that you need different springs?
    If you have a the OD, ID, wire diameter and overall length you should be able to match something up
    what about someone like Kibblewhite?
  29. hogfiddles
    I can't give official #'s, but CAN tell you that I can pull my 900 out of my neighbors drive just a couple houses down, and pass my house at 100mph. Carb clinic people can attest.....
  30. k-moe
    With a healthy engine a 900 should be a tick faster than a 750 in the 1/4. The 750 can run 11.99 with the right rider on it (and the sport fairing). I figure the 900 should be good for 11.8 even with a normal guy on board.
    The magazines ran the 550 in the mid 13's when new.
  31. XJ550H
    special cams need special springs in one of the other threads someone posted a link to cams on the list some of the cams needed different spring sets
    it was this thread and link
    http://www.megacyclecams.com/catalog/Page64.pdf
    when you change the lift you push the valves deeper into the cylinder stock springs may bind fighting the extra lift (may not be able to compress that much)
  32. darren ditmar
    eugene oregon
    i believe its the same concept as cutting the springs in your forks so that you can use a spacer to make them stiffer. you have to figure out how much gap you are replacing so that the springs dont bottom out before the rest of the contraption
  33. hanner73
    hanner73 New Member
    Illinois
    what about unipod air filters, heard good and bad, anyone have experience. I've heard a lot of complaints about removing carbs. Seems they would help olongapo with cleaning up engine bay.
  34. k-moe
    CV carbs and pods do not play well together. You can put them into a "get-along shirt," but they will only pretend to be friends (see link below, particularly page 5).
    XJ550H likes this.
  35. XJ550H
    oem is a uni pod;)
    it is not about the filter it is about the configuration with velocity stacks if you used a i piece filter on stacks it may get closer to where you need to be.
  36. Kickaha
    New Zealand
    I'm well aware of that but they dont always, case in point the Yoshi cams in my sidecar motor can use stock springs
    Spring bind is to do with insufficent installed height for the cam lift you're running so the coils end up stacked hard against each other, this can happen regardless of what spring you use and comes down to poor assembly and checking
  37. Jetfixer
    Make your bike running well with stock airbox...you can add a k&n filter. Pods can be a pain to make work properly , and you have to fabricate a braket to support carbs...the boots will be under a load and can crack if carbs are not supported. You will have to rejet carbs , bike might have power at high rpm and stumble at low rpm or vise vs verse. Mikuni and Hitachi carbs on the 550 and 650/ 750 just don' t like this . High velocity causes problem. I know some will disagree with me on what I stated some claim how great their bike runs with pods, but my xj750 seca runs sooo smooth at 85 mph I still have throttle left and I have stock airbox.
  38. darren ditmar
    eugene oregon
    i have tried pods on the 550 its not easy it can be done but not worth it you wont notice a power increase if you some how manage to tune them perfectly for the pods. theres just not enough back pressure and the carbs dont like to work right. not to say it cant be done but the stock air box works so much better its worth the hassle of pulling them out and putting them back in each time
