XJ600/FJ600 Custom Bike Build with Microsquirt
Discussion in 'XJ Modifications' started by Jonathan Calkins, Dec 8, 2015.
  1. Jonathan Calkins
    Jonathan Calkins Member
    Fargo, ND
    First time creating a thread, so bear with me, I'll learn the formatting as I go.
    1984 FJ600, same as the XJ600.
    Picked the bike up for $120 in 2012, have been in the process of building it into a cafe/brat/race style bike.
    The goal of this bike is to be able to bomb it down a gravel road, go on 3,000+ mile trips, and to handle well for an 80's bike in corners. In all three aspects, I'm only expecting it to be mediocre in all, and just be a well rounded bike.
    I have tossed around the idea of a turbo, and EFI for a while, and I have just recently bought a lot of componets for the EFI conversion. Throughout my build, I will be using most of my own ideas, as well as adapting what other people have done on their bikes. This will not be another lost and abandoned efi bike build. I will continue until it is "complete" (no bike is ever complete).
    Little back story of the bike:
    Purchased in 2012 off of craigslist, and it was in terrible shape. The wire harness had some housing solid core wiring in it, with wires twisted together with the twist caps. The carbs were stained green with old gas, and the gas in the tank was the so orange, I could hardly believe it was gas. It appeared that someone wrecked it a long time ago, and then let it sit in a field slue (spelling?).
    The wire harness was mutilated, as mentioned before. Power wires and ground wires were connected, causing the regulator, cdi, and coils to get excessively hot. After purchasing a wire harness off of fleabay, I could get spark, but only on one side. Did the usual diagnostic stuff, as well as changed the oil and filter, and found that the cdi was not driving one side of the coil. Bought a used cdi, and fixed the spark issue.
    On to the carbs. After cleaning them, the pilot jets were clogged and stuck in the carbs, with the heads stripped. A common thing that people don't understand, is that the carb stuff doesn't have to be super tight. In my experience, I have never had a main or pilot come loose. Anyway, using some ingenuity, the carbs were coming along. New floats, carb kit, o rings, all that stuff.
    Now lets fire it up. I had previously removed the exhaust to get at some shock stuff, and when I installed it back on, I left the mid/cross pipe out of the exhaust, less restriction is good right? Sure. (keep this in mind for a little bit). Put fuel in the bike and started cranking. Had to use the 'ole screwdriver bridging the solenoid trick because the hand controls were toast. Cranked about 6 times and it popped right off! Pretty good for not running for, to my knowledge, 16+ years. All of a sudden the fuel comes pouring out of the intake and overflow of the carbs, floats are too low, ok, no problem. I turned the gas off on the tank, because I figured I might as well let it run for a bit and cycle some oil, since it has not ran in quite a while. Well let me ask you a question. What happens to an engine when you cut the fuel? It used the fuel in the carbs and started to starve for fuel. Okay, no problem, it's expected, I have done it many times before to just let it run to get the fuel out. Well, when it starves for fuel and gets lean, it back fires. Shocker I know. So remember when I took the cross pipe out of the exhaust? All that fuel that poured out from the carbs went right under the engine where that pipe was. Exhaust likes to go through the path of least resistance, so when it backfired, it lit all the dripping gas on fire.
    So there I was, with no fire extinguisher or water to put my bike out. So trying to keep this short, I ruined my "new" wire harness, everything electrical on the bike, relays, solenoid, all that. Managed to take the tank off, seat, and I kicked the carbs out of it to separate the fire. Cleaned it up, and there it sat.
    So now, about a year later, it was time to get back at it. I have been currently building a wire harness from scratch, and ordered the started solenoid, using blade style fuses now, making my own starter relay, kill/start switch from a CBR1000rr, light/horn/signal switch from a 09 R6. After "finishing" version 1 of the harness, it fired right up again! Sweet. Shortened the wires to where they will actually be at when it's finished. Rode it around a bit with no brakes, just shifting down and using the kill switch and engine braking. It rips! And is loud as hell, because I chopped off the exhaust because it weighs a ton, and I will be welding up my own 4-1 exhaust. Open exhaust with pod filters, and it runs actually not bad. All the nay-sayers that talk about cv carbs are terrible with pods must just be unlucky because this thing runs great, a little lean, but that's fixable.
    Throughout this time, I have always wanted to convert it to EFI using microsquirt, why? Well why not. It is a learning experience and will transfer to other bikes in the future. So within the last year I have been consulting with a friend that has a lot of experience building 600+ hp evo's, lancers, and a 400 hp Hyundai Elantra drag car with 35 psi on stock engine, and buying EFI stuff, throttle bodies, sensors, and researching about it. This black Friday, I purchased a microsquirt controller and a CLT sensor.
    Urra likes this.
  2. Jonathan Calkins
    Fargo, ND
    Reserving some space in case I need to add some stuff.
  3. Jonathan Calkins
    Fargo, ND
    Pictures of the first steps of stripping in down and some small progress.
    One of the first pictures of the bike
    Taking apart the carbs
    Stripped down-ish
    2007 R6 front brake master cylinder and CBR1000rr kill/start switch. Very preliminary parts pictures and planning. Things will pick up in a bit.
  4. bkyger
    bkyger New Member
    Eastern Washington State
    Looking forward to watching your build!
    Jonathan Calkins likes this.
  5. Jonathan Calkins
    Fargo, ND
    Needed to do a frame swap, into a '85 frame, but when I got the title back, it said it was an '84, so '84 it is.
    A note for anyone thinking about swapping frames, there are a few differences in the frames. A couple fairing mount points are different (doesn't matter to me, it will be fairing-less for me), the coil bracket is different, so I assume that the coils are different from 84-85. Coil brackets are not an issue if you can weld. And for whatever reason, I could not get the exhaust to fit for the life of me, it was about a half inch off, so I cut it off at the headers.
    The stock exhaust must weigh close to 20lbs, so that is no good for the power to weight ratio anyway. Building a custom 4-1 exhaust with a Cone-Engineering collector, and a Dime City Cycles muffler.
    Engine in its "new" frame.
    Repacked the steering stem bearings, they look good, and the bearing races look fine. Good enough for an 80's bike, with unknown miles on frame or engine.
    Mounted up the forks and swing arm, and finished bolting the engine in. The engine is pretty damn heavy to be moving around by yourself, but I managed. After this I rewarded myself with a nice cold Budweiser.
  6. Jonathan Calkins
    Fargo, ND
    Built my own wire harness, very rough version, we'll call it Version 1.0.
    Here is a video of the first start up of the bike, and the first time ever moving under its own power ever since I have owned it, and for about 12-16 years before that.
    https://youtu.be/MTbY_Bal0aU
    The video has some earlier videos with the old leaking worn out tires, and some with the new tires. Here are a few pictures of the new tires.
    VERY IMPORTANT NOTE:
    The front tire, which on the internet says it is a 110/90 V18, but for whatever reason, the Shinko 230 110/90-18 16v is waaay taller than what was on it before. If you're not planning on running no front fender then, no problem, but the tire rubs on the stock fender. I am planning on just running no front fender until I need to replace the front tire.
    I'm not sure how this affects handling of the bike, since the rear tire is only about a half inch taller than the front now, I'll be sure to comment on the handling and take pictures of wear patterns of the tires once I start riding it.
    Wiring progress
  7. Jonathan Calkins
    Fargo, ND
    Fork seals were shot, and it needs new dust seals, but those can wait until the bike comes further along.
    Here is a fork tool that I welded up, welds are garbage, but it works and it won't see much stress or general use. More of a specialty tool, like most bike stuff.
    "A welder that grinds his welds isn't a good welder, he's a good grinder."
    It is used for holding the internals of the fork, so you can remove the bolt that in the bottom of the fork that holds it all together. You then pull everything out, and then you will be able to get the seals out.
    I was considering fabricating some of these fork disassembly tools, with some better welds, and maybe sell a couple, who knows.
    Who is working on '84 fj/xj's anymore anyway. Few and far between.
    Anyway, on to more bike stuff.
    JohnStonePhoto likes this.
  8. Jonathan Calkins
    Fargo, ND
    Now this build thread is all up to date. 12/9/15. Will be posting as I go. Probably won't go in great dept on the boring stuff, but I can send detailed pictures of parts if you have any questions.
    Got the Microsquirt in the mail yesterday, and throttle bodies from a 09 FZ6R, which are 33mm, which is only a 1mm increase from the carburetors, so I should not have many tuning issues, (famous last words).
    I also will be running a full data logging set up with Innovate products including the SSI-4 and the LC-2 wide band with their pocket logger. I used this set up on the blue 07 R6 that was in the previous pictures with great success. Going to adapt a GM knock sensor or a CBR600rr knock sensor to the FJ, I'm sure I will have to drill into the block somewhere. If all else fails, I made an electronic det-can out of an old personal listener thing that looks like a walk-man. Worked well for hearing the knock points.
    Little side note, the R6 has the largest diameter throttle tube of any other stock bike out there, if I recall correctly. This is desirable because who wants to have a long pull throttle, flapping your elbow around while shifting. But, the R6 cables do not fit with the stock FZ6R throttle cable mount, the pull cable is short. So there is three options, get a longer pull cable from Motion Pro or equivalent, get the cables from the FZ6R, or modify the stock cable bracket.
    These cables most likely will not work with the stock handle bars, or dirtbike bars anyway, so I am sure I will be getting new cables.
    Pictured: Microsquirt with CLT sensor, 07+ R6 Throttle and 09 FZ6R Throttle bodies.
    Detail of the "pull" cable that is too short.
  9. a100man
    a100man Well-Known Member
    Bedford, UK
    haha - love it. I had an XJ600 too (early 90s) it went well but if I recall used way more fuel that my mates modern (then) CBR600.. maybe the EFI will help on that aspect. Will you have to build special adapter rubbers for teh throttle bodies to head ? Do you also need a high-pressure fuel pump like in car injection systems ? I wouldn't really know wher to start with this so I wish you best of luck..
    Jetfixer and Jonathan Calkins like this.
  10. Jonathan Calkins
    Fargo, ND
    Yeah, apparently it is supposed to get 45-55 mpg, my R6 got about 42-50, so if I can keep it above 40 mpg, then I'll consider it a success for fuel mileage while cruising. I'm expecting to be putting in many hours of tuning.
    Yes, I will be making custom adapters for the intake boots, conveniently enough, the outside diameter of the stock boots are very close to the outside diameter of the new throttle bodies. So I will have a friend machine them out of aluminum, and then I will use silicon hose to mount them together. I will then use a die grinder to smooth out the transitions and such. I will probable post some simple CAD drawings of my ideas, and pictures of the parts as I make them. So many options and possibilities, so I'm willing to do whatever I have to, to make them fit. So far, in my head, it should work... hopefully.
    And yes, I will be getting a high pressure fuel pump. I'm not sure if I can use an in-tank fuel pump outside of a tank, or I'll just use some sort of an automotive one, maybe a Ford fuel pump, as I think that has been used before. I have also seen some people use a Honda Ricon atv fuel pump, but for my application, it looks like it might take up too much room. The tank on the FJ is huge, so I may try to fab up an in-tank pump. We'll see.
    cmmoriarty and a100man like this.
  11. a100man
    Bedford, UK
    Interesting ! What does teh R6 use for the pump - can that be adapted ? And sensors ? What inputs does teh microsquirt need ? Sorry for all the Qs - just interested as I looked into this for my VW bus at one point but never that seriously..
  12. hogfiddles
    Looks like we might have a real clean micro-squirt project the goes the distance this time.
    So many others get started, then big down with problems, then the people either give up or just disappear.
    This may be a good one to watch.
  13. Kickaha
    New Zealand
    I have an 2003 R1 intank fuel pump I would donate, however they are around 100mm diamter and 180mm long so I am not sure one would fit in one of those fuel tanks
    We run an external airtex E8445 fuel pump on the sidecar which is about 50mm diamter and 150mm long, but Airtex have a huge range of internal and external pumps
  14. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    I'm super interested in this. I have an FJ600 with less than functional carbs.
    One thing that I keep trying to figure out about FI setups is why bikes always have multiple throttle bodies where cars usually have one.
  15. a100man
    Bedford, UK
    Yeah but same with carbs though right ? Performance vs economy reasons I guess.
  16. JPaganel
    Minneapolis
    Vast majority of high performance FI cars run one TB.
    It's not the same with carbs. The difference is that with a single carb what travels through the intake runners is the air/fuel mixture. Long runners can be problematic, as it's going to start separating, mixture might get inconsistent. With port injection, the intake plenum has only air, fuel is sprayed right at the port.
  17. Jonathan Calkins
    Fargo, ND
    The R6 or R1's use an in-tank pump, it's fairly small, I don't know any numbers on it, but if those pumps will supply enough fuel for the R6 at 16,500 rpm, it will be fine for the FJ. Keep the questions coming, I'm learning this stuff as I go, and trying to give some actual, factual information that others can use on their projects.
  18. Jonathan Calkins
    Fargo, ND
    I would pay for postage or pay for it if necessary.
    What I was thinking for the in-tank pump is, that I would buy a used R1/R6 tank, 03-05 (just because they are older and not worth as much), ideally with damage to the tank, so it will be really cheap. I would then cut out the gas cap cup/bracket, and the fuel pump mount out of the tank. I could fabricate it, but it will be A: I may not have the tools to do it, or B: just time to make those pieces. I would then have a friend of mine TIG weld them in to the FJ tank (I really need a TIG).
    So then, I would be able to use a newer style gas cap, which would look cleaner, and have a lock. Not that the lock is important, but it's nice. I took out the lock mechanism on my cap because I only had one key, and I was getting a new ignition for it anyway.
    Thanks for the info on the dimensions of that pump. I'll have to do some measuring and see if I can get it to fit. It may be hard since there is a tunnel on the tank for the frame, we'll see.
    Thanks also for that info on the Aitrtex pump. Looks like something I might end up getting.
  19. Jonathan Calkins
    Fargo, ND
    I have wondered that too, with an FI set up, one could just have the injectors right outside of the ports, port injection, and then have one throttle body. I am not 100% sure, but I have read that sometimes if you have too short of intake runners, then it may be hard to tune. Like putting pods and open exhaust on an old bike. Some say you need a larger intake plenum, so running one throttle body may help. (That is before the carb or throttle body, so I'm not sure about having just a longer intake track after the throttle) I do know that the reason why the new R6's have the variable intake is so that they have long intake runners for low rpm, and then it lifts to shorten the runners at high rpm. Those are before the throttle bodies, so that will probably also make a difference.
    There is a guy that turbo'd a XS650 and he used injectors right at the ports, and one throttle body. That was also for ease of attaching the charge pipe to the throttle body. Turbo-ing might also make a difference, where the air is under pressure, and it probably does not matter as much how long the runners are after the throttle body.
    If I get around to it one day, maybe on another bike, and with some better machining skills, it would be interesting to see what each style would work best, on EFI.
    Ease of tuning, power, mileage. Make two separate systems, and try it out.
    I do agree with a100man, it probably comes down to performance vs. economy. If Honda isn't using one throttle body on their $600K(?) race bikes, then I'm sure they have a reason for it.
    Just like Yamaha engineers decided that the YZ450f makes more power with the cylinder head backwards.
    Maybe the air velocity is better with single throttle bodies. If so, it would be really interesting to see how single throttle bodies (that are the correct size for flow), would perform on a LS engine or some kind of V8. Sounds like a good science fair project haha
  20. Jonathan Calkins
    Fargo, ND
    Here are some initial ideas of mounting the throttle bodies to the FJ. I would make the intake boots that bolt to the engine out of alumium, similar design to the stock rubber ones. Then there will be a plate that I will either silicon hose and clamp with a flange on it, that bolts on to the intake boots of the new throttle bodies, or I will have the stock flange, weld on a tube, then weld that onto the other flange, that will then bolt on to the new throttle body flange.
    I was wondering about weight, and if I have those longer intake "boots" out of aluminum, will it put too much stress(moment arm) on the cylinder head and intake boot bolts? I will weigh the throttle bodies and carbs, to see what the difference is, then I'll make a decision. I might also just make a little bracket that the throttle bodies will bolt to, that will connect to the frame. Engine is hard mounted, and it doesn't really vibrate for an older bike, so we'll see. Might be a trial and error thing.
    The new intake boots being about an inch or two longer, shouldn't have an effect on tuning, but I'll find out I'm sure.
    Here are a few pictures. CAD drawings in the back.
    Where that 10mm ridged section, where the hose clamp goes, on the stock boot is (the top one in the picture) That will be where the plate will be, might have to use some imagination.
    Also, I bought an e85 content sensor, the Microsquirt has a pin for it on the ecu, so, why not? Nice thing about this project is, is that there will be nothing that is left of the 80's fuel system, so I should have no issues with e85. My reasoning on why I wanted to add it in is that say I go to a gas station, and they don't have 91, but they have e85, e15 or whatever, I can run it. Will the injectors be able to handle that extra fuel demand? I think so, since the injectors on a 03 r1, and injectors on a 05 r6 are the same, and the throttle bodies are the same, these injectors should be fine, since the FZ6r revs higher, and makes more power. The nice thing about the Megasquirt/Microsquirt, is that with that sensor, it will blend your e85 map, with your 91 map, so you'll have the right fueling and ignition timing for whatever percentage.
    And if anything, it will be a learning experience.
    Which is the whole concept behind this build. Build a bike that I like, hopefully others as well, and learn some new skills or general knowledge.
  21. Jonathan Calkins
    Fargo, ND
    Thanks, and thank you to everyone else for all the encouragment and ideas. I think I'm in it too far to turn back or give up now. I'm practically almost there! Not really, but I keep telling myself that.
    The FJ will be pretty nifty, if all goes right, it will be EFI, e85 capable, handle decent-ish, and an electronic steering stabilizer in in the works as well, using an arduino.
  22. Kickaha
    New Zealand
    I will donate the postage as well if you can use it
  23. JPaganel
    Minneapolis
  24. Jonathan Calkins
    Fargo, ND
    Well, thanks a lot! I'll let you know if I will end up being able to fit it in my design. Going to take some tank measurements and brainstorm my options.
  25. Isaacson06
    Isaacson06 Member
    Des Moines IA
    I've done this efi conversion on my xj650 look at some of my old post I'll be happy to help you
  26. Jonathan Calkins
    Fargo, ND
    I drew up a few designs in CAD quick, of the intake manifold design. It will be in three pieces, and then welded together. A friend of mine is a machinist, so I will most likely enlist his help.
    The darker gray is the piece that will mount to the stock FZ6r throttle body mounts. (The FZ ports are oval, so I will die grind them out to make the transitions smooth)
    The lighter gray is the part that will bolt to the FJ cylinder head.
    Here is a view looking "directly at the cylinder head"
    3D view
    And another
    I may shorten the distance between the two flanges, but that will be easy since the piece connecting the two will just be tubing that I can cut, and change angles.
  27. hogfiddles
    Since those posts were before the migration to this new platform, how about if you dig up the links to your forums?
  28. uhoh
    uhoh Member
    BC, Canada
    You may be able to get away with one piece depending on your bolt patterns.
  29. Jonathan Calkins
    Fargo, ND
    Great idea! That is a good looking flange. I actually thought about that, but the throttle bodies I have are shorter from one pair to the other, than the ports on the FJ head are. I could extend the fuel rail and the linkage connecting the two, but I don't mind having to offset the flanges and using angled tubing in between the flanges. If I was building a bike with more power and more race focused, then I would probably go your route with the flange, and then extend the rail and linkage.
  30. Jonathan Calkins
    Fargo, ND
    Update, a friend of mine is going to cut out the flanges, so that will really move things along.
    Once I get the flanges on, then I'll start wiring in the MS and get to setting up the tune. My new to me cylinder head and trigger wheel are here now, and the fuel pump in on the way.
  31. Jonathan Calkins
    Fargo, ND
    Worked on the subframe all Sunday and spent about 8 hours cutting, measuring, cutting and tweaking. I only had 6ft of tubing, so the saying "measure twice, cut once", couldn't have been more true. Spent a lot of time on the bends, but I want it to be perfect (or as close as it can get) and to have the right look I'm going for. Horrible Freight's pipe bender works really well for $90 and I have no complaints what-so-ever. I have found a new love for Harbor Freight, yeah some stuff isn't the greatest, but most of everything works well. There is more than one way to skin a cat, especially if you're crafty and resourceful.
    Little fun fact for the day, a clutch cable from a 07 R6 is about exactly the same as a clutch cable from a 1984 FJ. The only difference is the cable diameter, which is smaller on the R6. The cable from my 03 R1 looks about the same as well, so if you are ever in a bind and need a clutch cable, 03 R1 and 07 R6 clutch cables will fit on the FJ. I also have a 07 R6 clutch perch on the FJ solely because its easier to get 10 year old parts than 30 sometimes.
    I thought this cable thing was interesting, viewing it from an engineering and manufacturing standpoint. Why have 50 different clutch cables, when the designers can just factor that spec'd cable into their design. Pretty fun to think about and makes you wonder about what else all these bike have in common. No sense on reinventing the wheel.
    Here are some pictures
    Thinking of a 4 seater:
    Kidding
    Here is what it will roughly look like:
    TheCrazyGnat likes this.
  32. a100man
    Bedford, UK
    Thanks, I've been waiting for this update - hows' the efi going ?
  33. Jonathan Calkins
    Fargo, ND
    Slow, but I am making progress. I have all the parts I need, or at least I think I do. Now I am just waiting on the manifold flanges. After I get the flanges, finish the subframe and electronics tray, I will wire everything up, and start tuning/getting it to start. I also need to make my exhaust and weld in an o2 bung for the wideband.
    Most of everything that needs to get done is being hung up by not having the subframe and tray finished. I could just have everything loosely wired up, but then I wouldn't be making much progress on the fab work. I have been jumping around on all different aspects of the build, but now I am starting to get an order of what needs to get done, before I move on.
  34. Jonathan Calkins
    Fargo, ND
    I created some new flanges on CAD, because my old drawings were garbage and sent the drawing to the local metal working place. They CNC laser cut stuff, so that's pretty cool. A friend of mine laser cut some for me already, but I needed to make some changes, that I forgot to tell him when he made them the first time. So $58.03 later, I have new flanges. I will be welding them up sometime within the next week or so.
    If anyone would like this CAD file or are in need of anything to be drawn up to be cut out at your local metalworking place, please contact me. Small donations would be appreciated, but not required. I drew a new trigger wheel with some holes in it for some rotational weight reduction because anyone that knows me, knows that I'm a power to weight ratio snob haha.
    Here they are:
    They are almost exact matches, going to tweak one of the flanges by about a half of a millimeter, but other than that, they look great. This is the first time that I have drawn something in CAD, and actually had a part made from my drawings. The fact that they came out almost spot on, within tenths of a millimeter, is a real confidence booster.
    Why mild steel? Yes they are heavy compared to the aluminum ones my friend cut for me, but for this first prototype, steel is easier because I do not have an aluminum welder.
    Next laser cut part in the works: FJ fork brake mount to F4i Nissin calipers, and 05 R6 calipers. I have not decided which calipers I will use yet.
  35. Jonathan Calkins
    Fargo, ND
    Got a lot done over the 4th of July weekend. Battery/electronics tray, intake manifold, and speedometer, fuel pump, ignition coil brackets. Excuse the welds, I do not claim to be a master welder, this is the most I have ever welded. Everything appears to have good penetration, just not the cleanest looking.
    Everything that is to be mounted on the bike will have the nuts welded on to the frame, so I only have to bolt everything on and not fumble with nuts. I have worked on too many things that have nuts in hard to reach places that could have been welded on to simplify the install. Anyway, here are some pictures.
    Electronics tray. It has to be that deep because the microsquirt has to be mounted vertically
    Fuel pump bracket and new gas tank mount
    Intake manifold, spare cylinder head for mock up is very handy.
    I swear the welds look better in person
    Yeah the gap in the tank and the seat isn't ideal, and the tank line with the subframe is funky, but oh well. Things can always be changed. Needs to look good enough and run well enough to ride it to Maryland, then to Tennessee, then back to North Dakota the second week in August.
  36. Jonathan Calkins
    Fargo, ND
    Speedometer and ignition coil brackets.
    Made a riser for the back coil to be able to clear the plug for the wire harness, and the second coil will also need a small riser. Not a lot of room in there for 4 coils, but I made it work. My goal is to make this not look like a slap job, so I'm doing the best I can with the limited time and my current skill level, with the limited tools I have.
  37. k-moe
    You're using a MIG with flux-core wire aren't you? Your welds will never look fantastic, but that's not the point is it? If your stuff stays stuck then you did a good job. Quit bagging on yourself.
    If you want your welds to look better, get a die grinder and smooth them out. Low spots can be filled in with bronze rod and torch.
  38. Jonathan Calkins
    Fargo, ND
    Mig with .035 wire and C-25. Might have to take the die grinder to them, good idea
    Jetfixer likes this.
  39. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Welding through paint. Removing as much of the paint as possible prior to welding creates less porosity, a stronger weld and is less toxic. Adding the efi is interesting...I hope it works.
    Gary H.
  40. hogfiddles
    Keep the faith, Jonathan! You're getting there:)
    Hey, I'd love a copy of that cad file when you have it tweaked out just right--- private conversation was sent, too
  41. Jonathan Calkins
    Fargo, ND
    Completely agreed, everything that I weld is cleaned off. Have not been welding through any paint.
    rocs82650 likes this.
  42. a100man
    Bedford, UK
    Jonathan - nice work. I'm enjoying the progress the throttle bodies look really neat. I've often wondered if a xj550 seca tank would fit the FJ600 - would sure
    help the look IMHO.
    Cheers
    J
  43. Jonathan Calkins
    Fargo, ND
    Thanks! Once I buy a tig welder I'll try making a better looking one out of aluminum.
    Agreed, maybe a KZ650 tank or honda cb550. I do like the fact that the tank is about 5.67 gallons, if I can get 55 mpg for 5 gallons, that's 275 miles on one tank, and that is pretty good considering my R6 could only go about 170 before I had a half gallon left.
  44. uhoh
    uhoh Member
    BC, Canada
    Perhaps skip the TIG due to $$$ (unless you really want to learn it) and get the flanges/pipe in stainless steel and use a MAPP torch and some Safety-Silv 56 to solder/braze it. It will look gorgeous!
  45. Jonathan Calkins
    Fargo, ND
    Still working away at it. I completed the exhaust, and for my first go, I'd say I'm pretty satisfied with how it turned out. Welds could have been more flat, but everything will get wrapped in some exhaust wrap.
    Currently wiring away. Just like anything, has been taking me a lot longer than I expected.
    Anyway, here is a picture
    Really need to figure something out with my front fender. Rubs on the tire, and it will eventually ruin my fender. This tire is a real pain.
    To do list:
    Wiring
    Get it to start, tune it
    Brakes
    Exhaust hanger
    Front fender
    New brake light bracket
    Luggage rack
    Put some lipstick on this pig
    Good looking from a far, but far from good looking.
  46. k-moe
    Make a pair of brackets out of flat stock to raise the fender.
  47. rocs82650
    Middle Tennessee
    Is it monoshocked? Where's the shock(s)?
    Gary H.
  48. hogfiddles
    What is the fender from?
  49. Jonathan Calkins
    Fargo, ND
    Good call, I'll give that a whirl
  50. Jonathan Calkins
    Fargo, ND
    Stock 84 FJ. Or it was on the bike at least when I bought it. The tire is the size that is required in the service manual, but this brand is way taller and wider.
