XJ600-XJ900 Tank Interchange?
Discussion in 'XJ Technical Chat' started by yamasarus, Jan 25, 2010.
  1. yamasarus
    yamasarus Member
    Norh Carolina
    There is an XJ600 gas tank listed on Ebay and the seller has it listed for XJ650/XJ900. After looking closely the tank is very similar to the 900 tank. Does anyone know if they are interchangeable? This could open up many more resources.
  2. ronnie
    ronnie Member
    Searcy, Arkansas
    Actually, that is an FJ600 tank and while they visually look the same the 600 tank is not as long as a 900 tank.
  3. yamasarus
    yamasarus Member
    Norh Carolina
    Ronnie,
    Thanks for the info. It would have been nice to have a plan B!
  4. Slammy2k10
    Slammy2k10 New Member
    i was given a XJ750 tank in a trade, guy said it would fit my XJ650 , but tank is way to long
    -- Pvt Assanti , Sam
  5. markie
    markie Member
    Suffolk, England
    I have an XJ600 1989 and can give you some measurements if you want?
  6. TurkBroda182
    TurkBroda182 New Member
    Windsor, Ontario
    Hey all, I have an 84 750 RL with a 900 tank on it. It is rough...Is there a way to use an FJ600 tank?
  7. hogfiddles
    The 900rk and the 750rl are interchangeable as they are basically the same bike. The fj600 tank LOOKS the same but dimensions are different and is NOT a bolt on swap..
    It is possible to swap any tank... All you need is $$.
    There is already plenty of info regarding tanks here on the forums. Do your homework, search for tank swaps, interchangeability, etc...... And READ
  8. TurkBroda182
    Windsor, Ontario
    I'm new here , was that really necessary? Thanx for the help
  9. hogfiddles
    Since you're new, and you don't know the answers, yes-it is necessary.
    The fj600 tank is similar to the 750rl/900rk tank and from a distance may look almost the same. But, they are not. The XJ600 tank is completely different, and doesn't even remotely resemble the above-mentioned tanks, other than it being a fuel tank
    Here are some examples of what is here for you to search for---
    http://xjbikes.com/forums/threads/the-information-overload-hour.27544/#post-235031
    http://xjbikes.com/forums/threads/first-bike-a-good-find.65852/#post-463292
    Etc...... There are other threads around, too- you need to search, ask (as you did) but be ready for people to supply you with links to read, as well as simply answers to read.
    Also, here's More for you to read, too--
    http://www.xjbikes.com/forums/threads/the-information-overload-hour.27544/
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    There are a couple of tank swap threads out there, but I don't recall if the author covered the 600. That bike is not so common at this forum. Do a Gurgle search for "site: xjbikes tank swap". That search engine does a better job than the one on the forum.
  11. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    To all members that may not know: There are two XJ models...Seca and Maxim. This thread is discussing the Seca model.
    Gary H.
  12. William Firstbrook
    William Firstbrook New Member
    White rock British Columbia
    is there any way to bypass the tank sensor in the seca? i tried to take off the speedo unit and it started running horrible and then just switched the gas tank and its doing the same. can anyone tell me why and where the part is to fix, replace or bypass?
  13. hogfiddles
    Read
    http://www.xj4ever.com/HCP14180 battery sensor bypass.pdf
  14. hogfiddles
    Yes, but this thread is ALSO discussing the FJ ----
  15. William Firstbrook
    my battery sensor is fine its my fuel sensor that seems to be acting up. im pretty sure the fuel level senor in the new tank is bust but i dont see how that should affect the flow of fuel to the engine and there for make the bike run so poorly?[/QUOTE]
  16. hogfiddles
    Yeah.... I JUST realized that error and came back to edit--- you beat me to it. Lol My bad.
    The FUEL level sensor only tells the conputer/light that is should come on. It doesn't have anything to do with the bike running.
    If you were doing something with the speedo m, I'd first look around there and see if you disconnected something, or reconnected something wrong.
  17. William Firstbrook
    ya thats what i assumed i did reconnect the speedo and the bike was running perfectly again. why taking off the speedo makes the engine run poorly im still lost on. but assuming its connected properly cause it was running fine. had to replace the tank due to a leak in the old one and found a parts bike with a decent tank cleaned the inside and hooked it up using the same hoses and connectors as off the previous one and its backfiring and dieing as soon as i give it some throttle. it feels like it did when i had taken the speedo completely off so i assumed it as the same problem some kind f sensor but if you have any suggestions im at your mercy. thanks agiain[/QUOTE]
  18. hogfiddles
    Put the petcock on prime and try running it that way---
  19. k-moe
    [/QUOTE]
    Are yuo just disconnecting the speedometer able, or are you removing the whole cluster?
    The XJ750 has the systems monitor, which requires some rewiring to remove the whole cluster and still have the bike run right.
    Here's the wiring mods to remove the rectangular instruments
  20. William Firstbrook
    I did that it works a bit better I just noticed that the new cap I put know the tank doesn't close all the way I guess the problem is the suction?
  21. William Firstbrook
    Awesome that's just what I need to remove her cluster now just gotta grind it out thanks. But what part of the system monitor needs to be rewired I didn't see it in the chat? Cheers for the help
  22. k-moe
    Make note of the pencil marks. They show what wires need to be joined together after removing the instrument cluster.
  23. rocs82650
    Middle Tennessee
    Agreed but even with all the similarities the the FJ is not a XJ. I was trying to clear any confusion regarding the Seca and Maxim which also are different when it comes to tank swapping.
    Gary H.
  24. hogfiddles
    And that is EXACTLY why this forum says so.....
    rocs82650 likes this.
  25. quebecois59
    The sEca 900 tank has a 22 litre capacity and I think the FJ600 holds only 18 litres.
  26. hogfiddles
    Matt, looks as though you might have been hacked………
