XJ650 Gear Oil Question
Discussion in 'XJ Technical Chat' started by tbalonick, Oct 20, 2014.
  1. tbalonick
    tbalonick New Member
    Arizona
    Just a quick question I cant find a 100% answer on. I see the manual calls for either an 80 or 80/90 Hypoid GL-4 oil, locally all I can find is GL5 oil, is it safe to use this or should I just go online and order the GL4 stuff? Thanks.
    Stick with GL-4. I can't remember if there are any brass parts or zinc-plated parts in the final drive, but if there are GL-5 will eat them for lunch.
    tbalonick likes this.
  3. tbalonick
    Arizona
    Thats kinda what I was grasping from the difference between gl4 and 5. Thanks for the response, off to hunt for gl4.
  4. TIMEtoRIDE
    Rut-Roh !! . . .
  5. Rooster53
    From page 26 of the xj750RJ Owner's Manual:
    Recommended oil:
    SAE 80 API "GL-4" Hypoid gear oil
    If desired, an SAE 80W/90 hypoid gear oil
    may be used for all conditions.
    Note: --------------------------------------------
    "GL-4" is a quality and additive rating. "GL-
    5" or "GL-6" rated hypoid gear oils may also
    be used
    So, is this a misprint of sorts or can it be trusted?
  6. tcorbitt060813
    tcorbitt060813 New Member
    Sunbury Pa
    Would you use a full synthetic? I am looking at the oils I sell at my store and the only GL-4 I carry is an Amsoil product.
  7. k-moe
    This question "sort of" came up again. I looked in both my copies of the FSM and the Haynes and do not find the note about using GL-5 in either copy. This may be a case of a misprint in the owner's manual, or in the service manuals.
    Who has a spare final drive to tear into, and the time to do it?
