XJ650 to R6 Front End Conversion Step by Step
Discussion in 'XJ Modifications' started by Clownman, Oct 26, 2012.
  1. Clownman
    Clownman Member
    Hey guys, I have been lurking on here for a while now with minimal activity so I thought I would share my latest success with you.
    To start out I am turning my 1980 XJ650 into a cafe racer type of machine. While not your average cafe bike I have seen some pretty nice ones. So on to the pictures and how I did mine.
    First off you need to source a front end to use. I went with an ebay special, its a 2006 Yamaha R6 front end. I got it complete minus the levers and the front wheel and tire. If I am correct the '03-'12 stems should all be the same with only minor differences in the '05 braking system.
    Ok moving forward.... this is what I received in the mail.
    After taking both the 650 and the R6 stems apart I measured the bearing surfaces. The top bearing surface for the R6 stem in 30mm while the lower bearing surface is 31mm. Once that was established I moved back to the neck of the 650 to find that both the upper and lower bearing race diameters were 48mm.
    From there I went to Allballsracing.com to see if they had a direct conversion kit. They did not. While they offered the 30mm I.D. X 48mm O.D. bearing(PN: 99-3506-5) they do not make a 31mm I.D. version.
    So armed with that I went back to the R6 stem and measured more and determined that there was enough meat at the lower bearing surface to actually turn down the 31mm bearing surface to the required 30mm diameter needed.
    With that settled I had to determine the height of the bearings that I need the clear the lower portion of the neck and still fit the stem through the top. So the lower bearing seat is about 19mm up into the neck, with that I went back to Allballsracing.com and saw that they offer the needed bearing diameters in 3 different thicknesses, 15mm, 14mm and 12mm. So since the distance needed to clear the neck was 19mm, I decided to get the 15mm thick bearing and just make a spacer for the lower bearing. The dimensions of the needed spacer are as follows, 48mm O.D. X 30mm I.D X 4mm thick.
    After that I measured the top to be at about 11mm, so naturally the 12mm bearing(PN:99-3515-5) was needed there.
    So back to more pictures....
    Her you can see the 4mm spacer, seal, and the bearing (PN: 99-3506-5) on the lower bearing surface of the R6 stem.
    With that ready for the bike it was time to install the female portion in the 650. (PN:99-3506-5)
    With that in the top female section was installed. (PN:99-3515-5)
    Once they are installed it is time to slap it all together right? Wrong!!! With the first complete test fit it was clear that that the hole for the upper dust cover would need to be bigger and the thickness would need a trim as well. also needing attention was the booger weld on the neck. So after cleaning that up and trimming the cover it went together without a hitch.
    Checking the lower clearance yielded more space than I first imagined, plenty of clearance and no need to grind down the neck.
    With both the lower and upper triple in place it was time for a fitting of the forks, wheel and the clipons to see if they cleared the tank.
    I still need to modify the turning stops a bit but I should be able to get it pretty close to stock steering with the clipons flared out just a bit from the stock R6 positions. Clearance is a bit tight but it will be all good once the new stop is welded in.
    And finally step back to admire... (just the stock light sitting in there)
    For those that hate reading here is a "Quick and Dirty Recap"
    '03-'12 R6 Front end complete assembly
    Turn lower R6 stem bearing surface to 30mm
    Make 4mm spacer for lower bearing
    Lower bearing PN:99-3506-5
    Upper bearing PN:99-3515-5
    Trim upper dust cover, grind weld
    Install all parts and enjoy.
    V/R
    Chris
    Franz, Ketchup and mattia like this.
  2. mtnbikecrazy55
    sa-weeeeet! cant wait to see more!!
  3. skillet
    skillet Active Member
    SW TN
    NICE write-up (with pics even) and work! Those bars do look close...
    skillet
  4. Dudeman
    Dudeman New Member
    Perth, Australia
    Awesome how-to, detailed and concise.
  5. ThunderThighs69
    ThunderThighs69 New Member
    Looks nice. Did you notice if this ended up raising or lowering the front end significantly?
  6. PacNorWestHD
    PacNorWestHD Member
    Woodland Washington
    Nice! This is the kind of work and Mods that inspire me to want to pickup another XJ and do something like this.
  7. fintip
    fintip Member
    Austin
    Those handlebars really do look dangerously unusable.
    Looks good, though. Great work. :)
  8. Clownman
    Clownman Member
    Thanks everyone, once I get it a bit further along I will probably start a build blog. As for the clip on to tank clearance, I think it is just the picture, I have been on numerous sports bikes that have way worse clearance issues than this thing.
    In regards to the lowering issue, I think it lowed it about 2 inches. I am also running a 750 18" rear tire to get the look im after so it will have a slight rake forward, it will also help clear the exhaust that I will be running under the bike (2 into 2 exiting just in front of the rear wheel)
  9. MikesChevelle
    MikesChevelle Member
    That RC51 is a dream bike of mine
  10. skillet
    SW TN
    What type of exhaust are ya' talkin' about? "Store bought" or fab your own?
    skillet
    btw lookin' for ideas
  11. Huck
    Huck New Member
    Tampa FL
    I like what I'm seeing here. My questions are... Does this leave you with rims that no longer match? If you're still using the seca rims how are the brakes aligning for you?
    If you have time can you narrate that a bit and post more pics about how that's going for you?
  12. Clownman
    Clownman Member
    For the exhaust, I will be doing a custom setup, two 12" reverse cones under the center of the bike ending just before the rear tire.
    For the wheels yea they will be mismatched. I am using the 750 rear wheel and the r6 front wheel. I will be making aluminum insets that will fill the slots in the 750 wheel to make it look like large spokes rather than just thin slivers. Once they are both repainted the proper color I feel it you should not be able to tell that much of a difference front to rear. I would love to put full spoke wheel on it front and rear though.
    I will be starting a build blog soon once I get a bit of time from flight school stuff.
    -Chris
  13. Orange-n-Black
    Memphis Area
    What is the difference in axle diameters between the XJ and the R6?
  14. venlis
    venlis Member
    Finland
    huge.
    nice swap though.
    it looks like you cant turn the wheel much? how about moving the tank back a bit?
  15. Clownman
    Clownman Member
    The wheel movement is about 5* less than my roommates RC51. Not a huge difference but yea parking lots may be a challenge but everyday riding should be fine. Moving the tank back would require me moving the forward mounts, and the rear mount. Trying to get it all lined up perfectly again would be a pain in the ass, not really feeling like playing with that. If it is to much of a problem once test riding comes around, I will just pound the tank in a touch with a rubber hammer.
  16. theadbrewer
    theadbrewer Member
    Roseville MN
    Looks great want to do this to my 750 someday.
  17. venlis
    venlis Member
    Finland
    5 deg less doesnt sound that bad.. if it tuns out tight you can always just keep it in mind and steer away from small spots:)
    anyways it looks fffffffin cool!
  18. yoni
    yoni New Member
    Hi
    Thank you for this info.
    I would like to know if there are heavy vibrations from the front while riding
    fast?
    It looks very good but is it safe?
    I will appritiare any comment..
  19. Clownman
    Clownman Member
    Yoni, I have not ridden it yet, still waiting on a few more parts. Hopefully it will be rideable in a few weeks, Ill let ya know then. I am also planning on installing a steering stabilizer as well to take care of any slight vibrations.
  20. Erman
    Erman Member
    Oslo, Norway
    The pics are gone. Any chance to reupload them?
  21. Clownman
    Clownman Member
    Erman, I redid all the pictures, let me know if ou still cant see them and I cand send you the direct link to them all.
    Yoni, Today was the first ride with the new forks, I got it up to 68 mph with no vibrations of any kind. It is a bit touchy and reacts a lot faster than i imagined it would but thinking back it is almost exactly as my old R6 was. So far so good!!! Ill put some more miles on it soon and I will report back any adverse effects from the front end.
    -Chris
  22. Erman
    Erman Member
    Oslo, Norway
    The pictures are back. Thank you so much! Admirable how you managed to swap the forks.
    What about the wheel and brakes, did the stock bolt on to the new forks right away?
  23. Clownman
    Clownman Member
    I am using the stock R6 brakes and everything. The wheel is still off the R6 and I doubt that it will be changing. Thats a lot of testing and figuring out what works, and i am almost at my budget limit plus I like the look of the wide front tire matched with the rear.
  24. mtnbikecrazy55
    i personally like the look of the stock light still there
  25. Clownman
    Clownman Member
    I installed an aftermarket housing with a new lens but it is the same 8" light as the stock one. So it still looks the same just not chrome.
  26. remo
    remo Member
    Northern New Mexico,usa
    nice look to that bike! I just scored a very similar front end at the junkyard, and i'm considering whether to use all or just some of it, I paid $.40 a pound (about $5) for it! Still gotta run the #'s on it to determine exactly what its from to see which rims of mine will be compatible etc. But I figure the clipons it came with are worth it, by far, if thats all i end up using. So thanks for the excellent thread! If you don't wanna beat up your tank you might try customizing one off an old kz, pretty easy fit it seems to me. anyway nice work! I like that bike!
  27. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
  28. Clownman
    Clownman Member
    Remo, where on earth did you find it for so cheap!!!! I would love to have found a motorcycle scrap yard around here, I just got mine off ebay. I have thought about different tanks and even just modifying mine, I am gonna paint it next week so I gotta make a decision soon. Need to ride it more to make a decision though. As for the KZ tank, I will look into that, thanks for the heads up.
    HirsuitHeather, Just make sure you know the neck length of what your getting, the all balls racing conversions don't take that into consideration and only provide compatible bearings.
  29. worlds-fastest-xj-750
    worlds-fastest-xj-750 Member
    LITH illinois
    WOW!! very precise. So it looks like im gunna pass on the r6 forks, lol im just gunna cut the stock ones and figure out a way to cancle out the anti dive. But thanks for posting that in depth thread
  30. jtuner77
    jtuner77 New Member
    Anyone know if this will work on the 82 xj550 Maxim? Clownman do you have any extra spacers for sale?
  31. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    that is an awesome conversion, i would like to pick up another xj and mod it up also. something bigger than a 750 though would sweet.
  32. jtuner77
    jtuner77 New Member
  33. Clownman
    Clownman Member
    I am not sure if the necks are the same but they may be... As for the spacers, I do not, I had a local machine shop turn them down for me as I don't have access to a lathe right now. Should not be to expensive to get a single spacer made.
  34. moses
    moses New Member
    El Paso, Tx
    Hey Clownman sorry to bring this back, but had a question. How did you turn the r6s triple down the 1 mm needed? Or what would be the simplest way?
  35. Clownman
    Clownman Member
    The stem needs to be gingerly pressed out of the lower triple and turned on a lathe to the proper dimensions. While I could have done this myself if I had access to a lathe still, I had to have a local machine shop do it. Any machine shop worth a damn can easily do it for you and can make the spacer as well, your looking around 200 bucks depending on the shops hourly rate. I got lucky and my guy was very reasonable and worked with me on the price at 150. Should not be more than a few hours work, its a very simple and common process.
    Also not that you only need to turn it down where the bearing will be seated. Dont have them turn the whole lower portion of the stem down or it wont fit back into the triple.
  36. moses
    moses New Member
    El Paso, Tx
    If I'm pressing it out I'm just wondering if there would be any upside to just swapping in the xj stem as they both have the same lower diameter. Thanks for that info though
  37. moses
    moses New Member
    El Paso, Tx
  38. Clownman
    Clownman Member
    if they have the exact same dimensions (Dia / Height) where they are pressed into the lower tree, I don't see why it would not work. I know for a fact that the lower bearing surfaces are different diameters, thus having to get the R6 stem turned down. I never even bothered to check the lower diameter of the stem to see if they would just swap like that... I'm gonna feel real dumb if it was that easy...
    Post pics and your findings on here so we can see, I'm planning to do the same conversion on the XS I'm building so that would save a good bit of cash if I can just do that.
  39. moses
    moses New Member
    El Paso, Tx
    I only mentioned it because someone over on virago tech did a similar swap and that's what I think he did. I'll let you know though. Now I wish I had held off before ordering the bearings from allballs.
  40. moses
    moses New Member
    El Paso, Tx
  41. 750E-II_29Rbloke
    South Cheshire, UK
    Wow, took an hour and 42 minutes for that echo to bounce back! ^^ :D
  42. spinalator
    spinalator Member
    Regina, CANADA
    Did you check other front ends? The kids on VFRdiscussion have swapped GSXR and RC51 front ends on their VFR's. Some seemed easier than others. The R6 looks good on there. Very good work!
  43. Clownman
    Clownman Member
    thanks, I did not check other front ends though. I just ordered a whole front end off ebay and then took measurements and did what needed to be done to fit. If you have access to multiple front ends im sure you could find one that does not need to be machined but that would get vry expensive to just guess and check.
  44. kinen1
    kinen1 Member
    Perth, Western Australia
    that was very informative Clownman! just a question, hv u done anything to the fuel tank for more steering clearance? :)
    kinen1
  45. 77Rob
    77Rob New Member
    Cumbria
    That looks the dogs!!! Do you know if an R1 1998 front end will be the same process. Is the stem the same size...does it matter??
  46. mattia
    mattia New Member
    melbourne australia
    hey mate, i am doing the same swap of forks with my bike,
    i am having trubles because the steam since to be too small and i can not put the dubble bolts on the top of the steam,
    did you put only one?
    if you did, did you have any problems with steering ?
    thanks
  47. k-moe
    Those are jam nuts. You absolutely must have both installed for them to lock the stem in place with the correct bearing preload. It looks to me like there is room for the top jam nut to fit.
