XJ650RJ Project
Discussion in 'XJ Technical Chat' started by Dan Gardner, Mar 20, 2022.
  1. Andrew Nichols
    Andrew Nichols Active Member
    Minneapolis, MN
    Why yes, it is, it's cracked on the outside and the inside. 20210530_211932.jpg
  2. Franz
    My frame has been welded in that area. Have not seen one needing a repair on clutch side of the frame yet.
  3. Dan Gardner
    Minneapolis, MN
    Got everything sanded with 220 and one more round of primer.
    Andrew Nichols, Franz and faffi like this.
  4. Dan Gardner
    Minneapolis, MN
    The frame has been repaired and is now black again!
  5. Dan Gardner
    Minneapolis, MN
    Last step in the interior tank cleanup: the Caswell liner
  6. Andrew Nichols
    Minneapolis, MN
    Do you like Caswell better than POR 15?
  7. Dan Gardner
    Minneapolis, MN
    I’ve never tried the POR15.
  8. Andrew Nichols
    Minneapolis, MN
    Soak the inside of the tank with vinegar for a week, shaking occasionally, then dump it out and rinse. Dry it with a shop vac for 30 minutes and then dump in the POR 15 and manipulate the tank for about 10 minutes to make sure you coat everything. I've done 2 this way and I've been satisfied with the results.
    RideAlong420 and Franz like this.
  9. Franz
    I assume you did not use the POR15 tank clean prep. I have seen a few people doing that but I don't know if the sealer failed or not? How long ago did you do your tanks?
  10. Dan Gardner
    Minneapolis, MN
    Nothing wrong here
  11. Oblivion
    Oblivion Active Member
    Northeast Illinois
    What the ungodly . . .
  12. Andrew Nichols
    Minneapolis, MN
    I did them in May 2022 and it's still going strong. I only use non-oxy gas in it (not sure if ethanol will do anything to the liner, I just want to avoid crud buildup in the carbs).
  13. Franz
    Great l am going to try it. I have three tanks for my 900f but one is very rusty. I have seen people on YouTube using POR15 but not using the recommended tank clean products sold by the same company.
    Andrew Nichols likes this.
  14. Dan Gardner
    Minneapolis, MN
    Their metal prep seems a lot like a generic phosphoric acid metal prep - will remove rust, etch, and phosphorize the surface.
    I would (at the very least) clean the bulk of the rust out using electrolysis or an acid method, and then use phosphoric acid or their metal prep.
  15. Franz
    Yes it's all about the preparation getting the sealer to bond property. I will get the acid for it.
  16. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Was a grease gun used to bleed the brakes?
  17. Dan Gardner
    Minneapolis, MN
    Sprayed lots of parts today
    jayrodoh likes this.
  18. Huntchuks
    East Rochester, NY
    Looks very nice Dan, but don't you think you will wear the paint off the levers rather quickly?
  19. Dan Gardner
    Minneapolis, MN
    That's a good question. They came painted from the factory. I hope my paint job lasts at least as well as the OEM paint job.
    The OEM didn't do a very good job of prepping the substrate originally, that's for sure. The aluminum was still pretty shiny when I stripped the paint.
    The original paint must have been some sort of lacquer crap. It peeled off pretty easy after a couple minutes of soaking in lacquer thinner. Hopefully modern urethanes will perform better.
    chacal and Huntchuks like this.
  20. Dan Gardner
    Minneapolis, MN
    Got some paint from @chacal and got the final drive bits painted. Also got the fork lowers cleared. F43EDD77-CB6F-420E-A7D0-D2F7A59814D8.jpeg 1CFD9D7A-F5DE-4C2C-AED3-DB136CCBC1A3.jpeg
  21. Dan Gardner
    Minneapolis, MN
    Forks done!
    jayrodoh and Andrew Nichols like this.
  22. Dan Gardner
    Minneapolis, MN
    Anybody know how to get these gauge faces off without destroying them? I was hoping to get inside and clean/lube the mechanisms, but it seems like it may not be worth the risk. @hogfiddles ??
  23. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Dan, I haven't attempted it on these specific gages, but the construction of most is crimped together at assembly like a can of beans. Very careful deconstruction by a tiny screwdriver or prying device, lifting the crimp little by little. I've only done it on gages where they are junk if not opened and repaired, and it was ugly.
    But I've seen videos of it being done in a near restoration manner by folks with more patience than me, so it's possible.
  24. Dan Gardner
    Minneapolis, MN
    that’s what I’m afraid of - might do more harm than good. Maybe I’ll just try to get a little lubricant in where I can.
  25. hogfiddles
  26. Dan Gardner
    Minneapolis, MN
    Got the fuse box crossed off the list
    Franz and chacal like this.
  27. hogfiddles
    Did you get the gauges done?
  28. Dan Gardner
    Minneapolis, MN
    I decided not to tear into the gauges to try to clean and lube them. The whole “if it ain’t broke don’t fix it” thing. I will get new speedo and tach cables and hope for the best.
  29. Melnic
    Melnic Active Member
    Question on your fuse box, have you put the seat back on yet? I found that the fuse box I used was too tall. I did 2 things. I 3D printed a lower profile cover, then I mounted the fuse box further back on the top of the air filter cover. Mine is actually at an angle as my wires would not reach that far.
    RideAlong420 likes this.
  30. Dan Gardner
    Minneapolis, MN
    @Melnic - I did test fit the seat to check to see if I needed to modify anything - didn't see any problems. I don't think it is nearly as tight under the XJ650RJ seat as it is under the Maxim seat. I *do* need to replace the fuse box on my Maxim one of these days - I'm sure that will be more interesting.
  31. Huntchuks
    East Rochester, NY
    The beauty of the XJ700 series, no glass fuses and none under seat.
  32. chacal
    Well, almost none.................. :)
    XJ700 models used two separate fuse panels: one that contained the four secondary circuits, including two 10A fuses, and two 15A fuses, which is located within the instrument warning lights panel; and a separate 30A main circuit in-line fuse holder was located under the seat. These bikes used the later push-in style ATC fuses in the dash fuse panel from the factory; the 30A main circuit fuses were still the older "glass tube" AGC style fuse, and that is certainly a candidate for updating with the 30A ATC style in-line fuse holder HCP6833 or HCP16777 listed below.
  33. hogfiddles
    But there IS
  34. hogfiddles
    Oops…. Looks like Len beat me to it
  35. Huntchuks
    East Rochester, NY
    Except that an inline fuse holder is not as prone to failure as the clip style. Thanks for the correction though guys.;)
  36. Dan Gardner
    Minneapolis, MN
    Finally back on this project.
    She is going to be sassy!!
  37. Franz
    Nice paint finish.
  38. Dan Gardner
    Minneapolis, MN
    It may or may not have taken me a couple of attempts to achieve the level of finish I wanted...
    Next step decals - need to let this cure a few days and then get the decals applied.
  39. chacal
    Really, you should let it cure for about a month, or do the sniff-test: if you stick your nose right up to the paint, and sniff hard, if you still smell "paint", then it's not dried/cured (it's still off-gassing the solvent....which is what you're actually smelling....and depending on the product used, the solvent can take quite a while to fully evaporate). Stripes shouldn't be applied until the solvent is completely evaporated or you risk poor adhesion or even bubbles.
  40. Dan Gardner
    Minneapolis, MN
    Yes, I try to wait as long as possible. Supposed to be 80+ and sunny here this weekend. I will put it outside and get some infrared curing going on and hopefully get it fully baked a little more rapidly.
  41. Dan Gardner
    Minneapolis, MN
    The good news is that the other pieces that *didn't* need to be re-shot have been curing for a quite a while!!
  42. Dan Gardner
    Minneapolis, MN
    Just for anyone playing along at home - here is the rest of the plan for this tank and the rest of the parts:
    - Wet sand to 2000 (already done on the other parts)
    - Apply decals
    - Clear
    - Wet sand to 2000
    - Flow coat
    - cut and buff
  43. Dan Gardner
    Minneapolis, MN
    Other information for posterity: The base coat I used for this project is the House of Kolor S2-BC02 (Orion Silver).
    This is more flaky and sparkly than OEM.
    My goal on this project is to do "OEM but better". By that I mean OEM frame was flat black. I prefer gloss. I don't have the production constraints that the factory has, so if I want gloss, I'm going to do gloss. Similarly, OEM color on the body panels is kind of a dull-ish silver. I like a zazzier silver, so that's what I'm going to do since I don't have to paint hundreds per day and I am not bound by the same paint technology and mass production limitations of 1982.
    Anyhew, that's just my guiding principle on this project. You can agree or disagree, but that's what I'm doing.
  44. jayrodoh
    jayrodoh YimYam
    Cleveland
    100% agree with this approach, same thing I did with my Maxim years ago. Gloss frame, better paints, improved components where you can but end up with a stock bike. Can't wait to see the final product!!
  45. Dan Gardner
    Minneapolis, MN
    Finally got these done!!!
  46. chacal
    Dan the Man you are on a roll this week! Do you have a newsletter that I can subscribe to? :)
  47. Fuller56
    Fuller56 Well-Known Member
    Oh My, those bits are pretty! Yep, "Zazzier". Well done.
  48. hogfiddles
    It was a little early when I read this and I saw the word Taint….every time. And it STILL made SCENTS.
    Andrew Nichols and chacal like this.
