xj700 air cooled starting electrical problem
Discussion in 'XJ Technical Chat' started by joshs700n, Oct 3, 2013.
  1. joshs700n
    joshs700n Member
    mass
    hi everyone i have a problem with cranking my bike and the grinding sound that happens somtimes only right when you let off the button like it doesnt disengage fast enough? well i went to start the xj700n today and it just made a clicking noise and the clicking was coming out of this round solinoid thing in back of the battery where the positive wire comming off the battery goes into.then a black wire that connects to the same thing came broke off and it touched the frame and it started cranking over with the ignition off and it didnt do a grinding sound at all and it was cranking over for a good 5 seconds i know this has nothing to do with synthetic oil seeing as the grinding went away as it happened so my problems are electrical any suggestions?
  2. xjrida700
    xjrida700 New Member
    San Diego
    sounds like u blew the main relay next to the battery
  3. joshs700n
    joshs700n Member
    mass
    no it was the connection connecting to the starter motor i just needed to tighten wiggle it
