XJ700 versus Sportster
Discussion in 'XJ Technical Chat' started by neonjoe123, Feb 10, 2008.
Who's gonna be faster?
  1. XJ700 Maxim
    0 vote(s)
    0.0%
  2. Harley Sportster
    0 vote(s)
    0.0%
  1. neonjoe123
    neonjoe123 New Member
    Hey everyone haven't been on here for awhile so here goes:
    My college friend and I are arguing over who's bike is faster. I have a 1985 XJ700 which is completely stock. My friend has a 2001 Harley sportster with the 1200 conversion.
    I'm sure you guys know the specs on the maxim.
    The Sportster has 65 ft-lbs of torque @ 4200 and 65hp @ 6000, it redlines at 6500. The bike weighs about 490 and in first gear it redlines @ 40mph.
    Both my friend and I weigh the same weight are about equally skilled at riding.
    Who do you think will run a faster quarter mile???
    Oh and this spring/summer we are planning on going on out to the drag strip and settle it.
  2. MiCarl
    The maximum torque on my 650 is 31.8 lb-ft at 8Krpm. Don't have the number for the 700, but seems likely to be less than 40.
    He'll be putting out that much torque just off idle. He should pull away easily, only question is if you can catch him late in the run. I suspect you'll see his taillight the whole way.
  3. stereomind
    stereomind Active Member
    Tulsa, OK
    I think racing a Harley voids the warranty :mrgreen:
  4. Altus
    Altus Active Member
    London, Ontario
    He's got torque and horsepower on his side, and the only thing you have is a slightly lighter weight -- looks like you'd be losing that one
  5. blackdiscoball
    blackdiscoball Member
    dayton, Ohio
    ...if the harley doesnt break down...
  6. stereomind
    Tulsa, OK
    If I understand the specs correctly, the XJ700 produces 86hp at 9500 RPM. Torque is ~50 ft-lb at 8K RPM.
    So.. if you keep it near redline, you might have a chance.
  7. fonz
    fonz Member
    Philly burbs
    my brother has an 84 Sportster, i think its the 1200. i know ill lose but once his is all back together were gonna see how the 550 Seca holds up to it.
  8. danno
    danno Member
    Union Springs,New York
    Having owned both an '82 Maxim 750 and a '00 Sportster 1200,I can tell you that the 1200 will be quicker of the line,but after about 110 mph,the Harley's show is over. If your friend has the reverse dome Wiseco conversion (no head modifictions needed),I would say you have it in the bag. If he used the Buell upgrade,I would be inclined to believe that you have your work cut out for you.
  9. neonjoe123
    Thanks for the replies guys!!
  10. danno
    danno Member
    If your brother's Sporty is an '84,it is a 1000,and it is an ironhead.Harley 1200 Sportsters are powered by the Evolution engine design.And don't discount your Seca,those 550s are little screamers!
  11. fonz
    fonz Member
    Philly burbs
    I have heard him mention something about it being an Ironhead. at first i couldnt keep track between him and his friends, ones got a 62 Panhead another has a flathead and then this ones got a shovelhead. im sure there will be a few chances to see how the Seca and Sportster match up this summer.
  12. MAX-X
    MAX-X Member
    Ohio
    Just my 2 cents, My buddy has a 2005 Sporster 1200 & we were horsing around, he took off on me, by the time I was winding out 3rd going into 4th he was in my mirror, & a little disapointed that an old 700 whipped his new 1200
  13. RickCoMatic
    You could win if your bike is tuned razor sharp. You'd have to have the Pilot Mixtures set a shade Lean for Maximum Acceleration.
    You'd probably lose the hole shot. He have the torque to get his weight moving faster.
    But once you get that 700 over to the right hand side of the tach ... you'd have to keep it there and not miss a shift.
    You'd be Redlining ... but, your Red-lined Bike would be pulling a lot less weight ... so, in terms of HP -to- Weight Ratio ... you'd have a factor that would keep you in the photograph instead of getting your side covers blown off.
    I go "Hunting" Sportsters and Buells on the weekends with my 900.
    I have the the Rev-limiter set at 87-50; but I turn it off on Sunday!!!
    When I'm up in New Hampshire where it seems like you never stop going uphill; I always "Play" with the Harley Boys.
    I drop it from 5th into a Matched-revving 3rd and then just twist it wide open until the bike gets close to 11,000 revs ... uphill!
    That's enough to make the 900 stay within the top of its power curve and put the V-Twins close to blow-up on their tachs.
    Once they figure out that the Inline-4 can out-rev them and match them for
    the uphill accelerations ... they just usually let me go.
    Race him uphill and you got a shot at winning.
    But, don't run for "Slips"
    You never know when you'll meet a guy with aftermarket Cams!!!
  14. MaximumX
    MaximumX Member
    Ottawa, Canada
    I ride a XJ750X and I've embarrassed more than a few HD's in the past... That's not to say that I have been dusted a couple of times by guys with a little something extra "under the hood".
    My advice will echo everyone else's: Launch hard and keep the revs up in the 7-10k range.
  15. MACDBF
    MACDBF Member
    Halifax, NS. Canada
    I agrre with the guys, keep the revs up, and hit her hard off the get go. Should be a pretty even race at the end. Good luck!
    Mac
  16. yamyboy
    yamyboy Member
    Toronto Ont Canada
    NOS is fun LOL buld a NOS bike it wont last 2 long and you will have 2 fix it all the time but youll beat the pants off him if you dont blow up first
  17. cruzerjd
    cruzerjd Member
    Eugene, Oregon
    Yeah.... lets see, stock XJ700, 1/4 mile at about 12.6 @105, Sportster 1200 1/4 mile of 13.5 @ 95. Thats the new sportster too. Older bike amy be slower. If you can't beat that go home and practice. Hole shot the hog rider than rev the piss out of it. I can run even with a S&S motor Harley big twin with my 650 Seca. He has 95 hp and gobs of torque, but not much top end and a ton of weight against him. I have to rev it a bit and keep it above 6000 rpm's though.
  18. RickCoMatic
    Lean over that tank ... keep your wind resistance down low ... leave your tool kit, wallet and comb with a friend.
    Wind-up the XJ and get-on-it!
    Don't look back ... just keep your eyes peeking over the instruments and go for the ride of your life.
    Don't forget to check the oil. Don't be running those high revs with anything but a full peek-a-boo window full of oil!
  19. danno
    danno Member
    Good advice,Rick. But you forgot 2 other weight saving procedures;
    1) Get a haircut.
    2) Don't wear any underwear. (There is a good chance you'll soil them,anyway.)
  20. RickCoMatic
    ROTFLMAO!!!!
    Yea, right. And if a cop stops you get off the bike and fake having a seizure until the ambulance gets there ...
    He might forget the ticket and think he's got to save your life !!!
  21. bluzglide
    bluzglide Member
    Sporties are not fast, they are quick. But....they aren't as quick as a well tuned four cylinder. Figures (HP & torque) aside, they Yammie will walk all over the Harley just like the Kaw Mach I walked all over everything in its day, and will still walk all over most things.Multi-cylinder bike rev up so much faster than big flywheel v-twins. The Harley takes longer to rev up and tops out at a much lower RPM. I owned Harleys most of my life and even a 650RJ scares the bejeebers out of me. No H-D ever did that regardless of displacement. If I had to bet on the outcome of a race between the XL and the XJ my money would be on the Yammie all the way!
    Dave
    Ace of Clubs
  22. schmuckaholic
    California
    Hmmm. I'm of the opinion that we're comparing apples and oranges -- a 700cc engine vs one that's been bored out to almost twice that.
    I think a more fair test would be to run the race against a Sportster with a stock 883 engine; actually, it might be interesting to run against both engines and compare the results.
  23. neonjoe123
    I had a big multi-variable calc exam yesterday that I've been studying for so I haven't checked this thread in awhile. I am excited and maybe a bit surprised on the amount of feedback I got. Thanks everyone for all the support on this thread!
    So far we still have a bit of snow on the ground but were getting close to hitting the 50's pretty soon. Hopefully it will be warm enough to ride soon. Then they have to clear all that darn salt off the road.
    Oh and by the way guys my XJ was a barn bike before I brought her back to life. So it's only got about 8,000 miles on it :p
  24. stereomind
    Tulsa, OK
    That's the story of a good majority of XJ's on this forum... My 550 spent 20 years collecting dust. It had 8700 miles when I got it, and now it's just over 13K.
