XJ750A 1981 Shim diameter
Discussion in 'Hangout Lounge' started by sanglasmick, Oct 1, 2013.
  1. sanglasmick
    sanglasmick Member
    Wexford, Ireland
    Hi Guys,
    I have a 1981 XJ750A and was wondering what diameter the shims for the valve buckets are. Are they 29mm or 29.5mm?
    I need four shims 2.65 thick but seem to be having trouble finding the right diameter here in Ireland.
    Thanks in advance for the help.
  2. patmac6075
    patmac6075 Active Member
    MKE
    I'm confident enough to say they are 29mm...well at least that's what bought for my '83 XJ750R. If you can wait until the weekend...I'll be able to tell you for sure.
  3. patmac6075
    MKE
  4. sanglasmick
    sanglasmick Member
    Wexford, Ireland
    Hey thanks PatMac, that's what I thought.
    I believe they are the same on the old Z or KZ air cooled Kawasaki's. And I think Suzuki used 29.5mm?
    I appreciate the help.
  5. FtUp
    FtUp Well-Known Member
    pacific northwest
  6. biggs500
    biggs500 Active Member
    Sherwood WI
    29mm. Also Kawasaki shims from the same era will work. You do know that XJ4Ever ships overseas, don't you?
  7. bendoza
    bendoza Member
    portland, or
    they are 29. but.. i picked up some 29s from a shop that were for kawasaki bikes and i spent an hour trying to get it in. they are not slightly beveled or something. you will not get it to fit. ordered the right ones for my yamaha and they plopped right in. just be careful when ordering.
  8. sanglasmick
    sanglasmick Member
    Wexford, Ireland
    Thanks again guys,
    I priced Chacal on some stuff before, and I know he will be my savior some day, but he can be expensive.
    I have a local guy who will grind to spec for €5 a shim, (so no shipping and tax costs). I have spare shims that are too big.
  9. patmac6075
    MKE
    I'm certainly not one of the "experts" around here, but I wouldn't have somebody grind your shims to size...my understanding is the shims are hardened and grinding the will remove that...
    You should be able to find a local motorcycle shop who will sell you what you need (FYI..most technician have their own shims...as a last resort ask the service writer to see if any techs will sell you what you need). Also, don't forget eBay...plenty for sale there...for a couple extra bucks most will ship them across the Pond.
  10. sanglasmick
    sanglasmick Member
    Wexford, Ireland
    Thanks PatMac, the guy who said he would grind them is an engineer who runs his own shop. It would have been a last resort for me, but he is a guy I trust. Maybe the shims are only hardened on one side?
    I must admit, I thought I would get a lot more negative vibe, at the suggestion of grinding the shims!
    I'm a bit impatient as the bike is now off the road for nearly two weeks. I have found a shop which has swapped two of my shims for the correct size, and I have ordered two from Yambits.co.uk for €15 shipped. So good news. ( Sorry should have read €30 shipped). Gets expensive real quick!
  11. bigfitz52
    NO GRINDING SHIMS!!!
    They are indeed only surface hardened, and it doesn't go very deep.
    Howzat?
  12. sanglasmick
    sanglasmick Member
    Wexford, Ireland
    AHA! I knew I'd get you big fitz!!
  13. sanglasmick
    sanglasmick Member
    Wexford, Ireland
    What about grinding the other side?
  14. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
  15. bigfitz52
    A couple of years ago, we had this debate here. One of our members at the time was a metallurgist, and he sliced a shim and got electron microscope pictures of it that clearly showed how deep the hardening didn't go.
    I'll see if I can find it. He posted the pics.
  16. zilu
    zilu New Member
    Baltimore, MD
    Ditto to what cyclenoob said, I got the from the same ebay seller last week and they fit perfectly. Received them in 2 days after I placed the order (west coast to east coast).
