YICS TOOL
Discussion in 'XJ Technical Chat' started by wizard, Apr 7, 2008.
  1. wizard
    does it matter which side you insert the YICS tool from & what is the easiest way to remove an end cap?
  2. chacal
    No, either side will work, and by end cap, do you mean the bolt that seals off the YICS passage in the cylinder? If so, then you use a proper size wrench!
  3. wizard
    ah, perhaps this motor is not the YICS model!
    engine no: 5N1-000844. does this ring any bells with anyone?
  4. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    The white arrow points to one of the yics bolts
      File size:
      5.3 KB
      1,175
  5. Injuhneer
    Injuhneer Member
    SE Arizona
    There were many early XJs build pre-YICS. As I recall it was 1980-81 with a few very late 1982 models.
    I'd ahve to check the SN to be sure but if the passage plug is not on the back side of the head it is not a YICS motor.
