YICS
Discussion in 'XJ Technical Chat' started by mooch, Feb 11, 2012.
  1. mooch
    mooch Member
    Dayton, Ohio
    I have heard about a YICS eliminator and was wondering what it is. Does any one know?
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    It shuts off the Yamaha Induction Control System ports. It's the passage running right below the manifold boots. It has two symmetrical bolts on either side of your bike. There are several forums referencing the "YICS". According to our guru's they are unsure of why Yamaha decided to stop making this System a part of the manufacturing process. I have no clue. Some of the post I've read say that once you install it, leave it in. Others say don't. The instructions I received with mine says to leave it in. The instructions also say you "must" re-synch your carbs at the time of the installation.
  3. mooch
    mooch Member
    Dayton, Ohio
    Thank you!
  4. bigfitz52
    YICS provided increased performance and improved fuel economy on the engines it was built with.
    Blocking it off and leaving it blocked is completely unnecessary and will cost you in terms of fuel economy at the very least.
    We block it on the YICS motors only to do a running vacuum sync.
    YICS:
  5. mooch
    mooch Member
    Dayton, Ohio
    Thanks Fitz!
  6. streetbrawler750
    streetbrawler750 Member
    Minnesota
    I always thought YICS stood for Yamaha Is Cool Sucka
  7. TIMEtoRIDE
    The aluminum tool with "O" rings ends up with sliced "O" rings, maybe that's why they don't want you to remove and inspect it.
    The more proper tool has sections of hi-temp hose that expand after installation and doesn't shred with use.
  8. bigfitz52
    Plus we don't leave the "more proper" tool in place; it's for performing an adjustment and then it's removed.
