easy carb tuning Question
Discussion in 'XJ Technical Chat' started by joejr2, Jun 15, 2016.
  1. joejr2
    Santa Fe,NM
    Do the mixture screws add more air to the fuel mix as they are backed out ? If I pull my plugs
    and they are sooty shouldn't I add more air to the fuel mix ? To get two of my bikes to idle at
    1.75 k I have to increase the rpms with the idle knob. Then, after riding a few miles, I stop at a light
    and the idle speed is 4-5 k rpms. I pull over, turn the idle knob in reverse till it slows to 1.75 k again.
    I live at 7,500' elevation. If I pull the air filter and the engine speeds up would that indicate an over-rich
    problem ? I thoroughly cleaned both carbs. On the second one I installed new throttle shaft seals and
    new mixture screw "0" rings+washers. But, they both behave the same. Mixture screw 2.5 turns out.
    "82"650 rj seca, "82" 650 maxim j.
  2. schmuckaholic
    California
    No. The mixture screw sits in a part of the carb known as the pilot circuit. What it does is feed the air/fuel mixture (it's already premixed at this point) into the carb throat just past the butterfly -- it's also referred to as the "idle" circuit.
    If you want to get a look at the insides of these things, hit up the XJ4Ever site and discover that Your Carbs Are Naked.
    That's a bit high -- idle should be just over 1000 rpm.
  3. waldreps
    waldreps Active Member
    Henning, MN
    The mixture screw richens the mixture when turned out and leans it when turned in. As far as your sooty plugs, this is from Len(member name Chacal) at XJ4Ever, the resident parts guru:
    Why are my plugs carbon-fouled (dry, sooty black deposits)?:
    - Carbon fouling is the result of incomplete combustion----for any reason. It is most often associated with an overly rich fuel mixture (whatever the cause), but can also be caused by an overly lean fuel mixture (or poor spark, etc.) In a lean-mixture condition, most of the un-burnt mixture gets pumped out the tailpipe, but some fuel droplets remain in the cylinder and add themselves to the next intake charge. That's not a very precise way of metering the mixture, so when it's finally rich enough for a spark to ignite, that particular charge may be too rich, resulting in incomplete combustion and plug fouling. So carbon-fouled plugs can be due to rich or lean conditions.......your Colortune spark plug will tell you for sure. If you have a light blue or white-ish flame, intermittent flame, and/or intermittent flashes of yellow within an otherwise white-ish flame, then your fuel mixture is too lean.
  4. Jetfixer
    Your carbs are NOT synched right or you have a vacuum leak (usually intake boots or gaskets)
  5. Jetfixer
    If idle is high like you describe one of your carbs is putting more fuel in than the others ( it settles down by adjusting knob ). You will need either the 4 vacuum gauge set up( MY preference) or build yourself the 2 bottle synch manometer .
  6. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Did you bench synch each rack after you cleaned them?
    Gary H.
  7. joejr2
    Santa Fe,NM
    I bench synched with a sliver of plastic card before I reinstalled the carbs. New throttle shaft seals and an immaculate
    cleaning job. Today I pulled the plugs and examined them. #1-light soot cleaned up with a toothbrush, #2- soot just a
    bit heavier, #3- very light soot,wet with gas, #4- same as #3. I cleaned them and replaced them and tested for spark.
    All the plugs were getting a strong spark on the tester. I changed the air filter from a foam one to paper and started it, it idled
    faster than before and I turned it down to 1.25 K from 2k. I remembered that when I disassembled the carbs before cleaning
    the mixture screws were set at 1-1.5 turns from bottom. When I reset them I used the standard 2.5 turns out from bottom. Maybe I set them
    too rich. Should I turn 1+2 in .25 turns and 3+4 .5 turns in to lean the mixture ? And, what comes first, adjusting the mixture or
    synchronizing the carbs ? Yes, I set the valve shims first. I have the 2 bottle set-up.
  8. k-moe
    How many turns the idle mixture screws get depends on the thread pitch of the screws. Fine gets 2.5 turns, coarse gets 1.5.
    Does the Maxim have a YICS engine, or a non-YICS engine?
    More importantly are the idle mix screws fine pitch, or coarse?
    chacal likes this.
  9. joejr2
    Santa Fe,NM
    I'll have to pull one of them in the morning and see.Thanks
  10. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Correct me if I am wrong; if your valve clearances are out of spec - this to can create incomplete combustion
  11. k-moe
    Correct.
  12. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Compression numbers may help understand the condition of the engine. Low compression on a couple of cylinders won't help matters much either.
    rocs82650 likes this.
  13. rocs82650
    Middle Tennessee
    Gary H.
  14. MN-Maxims
    Saint Paul, MN
    The integrity of the engine is good seal on all cylinders. If there are compression issues there will be tuning and scyncing issues.
  15. rocs82650
    Middle Tennessee
    +1. Has compression been tested?
    Gary H.
  16. joejr2
    Santa Fe,NM
    the compression tested 118, 122, 120, 119 lbs. I tried synchronizing the carbs, but the yics tool I purchased
    on ebay ( an aluminun rod with strategically placed "0" rings ) didn't work, the "0" rings fell off. But not before I messed
    up the bench synch. so, I turned in the mixture screws, 1+2 one quarter and 3+4 one half turn. I pulled the carbs, bench synched
    them again with a strip of credit card and reinstalled them. this time the bike ran more smoothly. The idle held at about 1.25 k
    and rose to 1.75 k at the first stop light after a 10 mile run but dropped to 1.25 k when I goosed the throttle. The next move will
    be building a home made yics tool that will actually block off the ports. The first thing I did on that engine was to swap the valve
    shims around to put them in spec.
  17. k-moe
    You don't need the YICS blocking tool to do a running synch.
    hogfiddles likes this.
  18. AZxj750R
    AZxj750R New Member
    AZ
    Hi Why do you not need the YICS Blocking tool to sync carb's while running? Thanks I know this is an old post
  19. XJ550H
    general consensus is it is not needed. without tool you are realworld tune as bike is not riden with tool in place. not using tool will get you where you need to be.
    if you are racing you may want to use the tool for tha added 100th of a second.
    if you chose the tool make sure bore is clean and the tiny holes into head are clear.
    cgutz likes this.
  20. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Plus one, don't bother with the tool. If you were racing you still wouldn't use it.
    Most peeps on here use a colortune to set mixture screws. I do it by ear, but it's not easy, and not guaranteed.
    cgutz and k-moe like this.
  21. Turbobob23
    Turbobob23 Member
    Fredericton N.B. Canada
    Where can a guy find a color tune. Been looking for one with no luck
  22. Jetfixer
    I bought one off of eBay brand new a couple of years ago , great investment as I recall gave 40$
    Turbobob23 likes this.
  23. Polock
    color tune ? just take the pipes off and look at the fire color :)
  24. Turbobob23
    Turbobob23 Member
    Thats a last resort for me lol
  25. XJ550H
    xj4ever.com sells them
    email them for a quote
  26. Turbobob23
    Turbobob23 Member
    Found them. Certainly not $40 anymore lol. So what size do the xj's take? 12mm or 14mm?
  27. Jetfixer
    14mm
  28. XJ550H
    depends on which xj you have same size as sparkplug
  29. Turbobob23
    Turbobob23 Member
    I have the xj1100
  30. XJ550H
    14 mm spark plug NKG BP6ES is the spec plug for your bike
    NGK plugs that begin with the letter "C" are 10mm,
    NGK plugs that begin with the letter "D" are 12mm
    NGK plugs that begin with the letter "B" are 14mm,
    from xj4ever catalog
    HCP95C Aftermarket Gunson COLORTUNE TUNING SPARK PLUG KIT, for 14mm spark plugs. NOTE: NGK plugs that begin with the letter "B" are 14mm, and are used on all XJ650, XJ700 non-X, XJ750 non-X, XJ900RK, RL, F, N, and FN models, XJ1100, and all XS1100 models.
  31. Turbobob23
    Turbobob23 Member
    Thanks! Thats great info to have as I'm working on an xj700n as well.
