XJ550 Maxim Carburetor
Discussion in 'XJ Technical Chat' started by CurleyJ00, Mar 25, 2017.
Tags:
  1. CurleyJ00
    CurleyJ00 New Member
    Pennsylvania
    I got my XJ550 Maxim running but the carburetor still leaks gas from #3 and #4. I replaced the bowl gaskets but it still leaks. Any suggestions? Also if anyone has a diagram of the carburetor like an exploded view?
  2. TheCrazyGnat
    Central PA
    Leaks how? Down the side of the bowls? Into the crank case?
    Either floats set too high, needles not sealing, petcock not working, or some combination thereof.
  3. CurleyJ00
    Pennsylvania
    Leaks down the side of the bowls.
  4. TheCrazyGnat
    Central PA
    Ok, how much work have you done to your carbs? Are they still on your bike?
  5. CurleyJ00
    Pennsylvania
    I took them off because it was leaking everywhere. All I did was change the bowl gaskets
  6. k-moe
    Needs more than that. Your fuel rail o-rings are probably shot. In the long run it's better to break the rack and do a thorough refurbishing.
    IN THE CHURCH OF CLEAN
    TheCrazyGnat likes this.
  7. TheCrazyGnat
    Central PA
    Definitely read the link above. It sounds like you are getting everything sorted for a project bike. The carbs should definitely be attended to with special attention. If the fuel rails are the culprit you'll need to split the rack regardless, so you might as well take care of the whole shebang. There are a ton of members here who have gone through the process and can help you along.
    Stumplifter likes this.
  8. XJ550H
  9. TheCrazyGnat
    Central PA
    This link has a cut away to Conway Twitty:
  10. CurleyJ00
    Pennsylvania
    I have all the parts on the way to rebuild my carb. My main issue was 3 and 4 leaking fuel but I figured I might as well rebuild all if I'm going through the trouble. Anyone know where I can find the main supply line that splits into a T? Also #4 had a loose needle, how do I fix this? And what parts are safe to polish inside the carb?
  11. XJ550H
  12. k-moe
    The link I provided above has all the info you need about rebuilding you carbs.
    Start a conversation with Chacal for the correct parts.
    I'd also like to know which needle is loose. There are three: The main fuel needle, the float needle, and the idle mixture needle (commonly referred to as the pilot screw).
  13. CurleyJ00
    Pennsylvania
    It's the float needle. Since it's loose I'm assuming that one of the problems is that it doesn't seal.
  14. XJ550H
    it has an oring around it to seal it ,held down by a little retainer bracket
  15. CurleyJ00
    Pennsylvania
    I saw the retainer bracket but didn't want mess with anything yet. I'll take it apart and check it out
  16. k-moe
    Is the needle loose or the seat for the needle? The float needle is a loose fit in the seat bore, and seals when the cone of the needle is pressed against the conical seat by the float tang.
    If the seat is loose in its bore then you'll need new o-rings. This is a sign that all the rubber parts should be replaced (except for the slide diaphragms, unless they have holes, or are cracking).
  17. CurleyJ00
    Pennsylvania
    The actual needle. Took the float out and there is play in it.
  18. k-moe
    There is supposed to be some play. It's a loose fit in the bore so that the needle can't bind. If it's really sloppy then you should replace the needles and the seats.
    You might see if the problem is the needle or the seat by swapping the needle from another carb to compare the fit.
  19. CurleyJ00
    Pennsylvania
    Are the screws/bolts on the carb specific or could I replace them with ones from the hardware store? Many of them are rusted and are probably gonna get stripped
  20. k-moe
    1. Get a JIS screwdriver (recommended) or a hand impact driver (should get both really), or the screws will all get stripped no matter what. None of the crosshead screws on the bike are Phillips.
    2. They are standard thread sizes, but you will need to shorten a few in order to allow them to fit. The easier way is to order screws from Chacal if it's in your budget. Either way you can switch over to caphead screws if you like.
  21. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Eliminate future headaches...take the entire rack to Church.
    Gary H.
    hogfiddles and k-moe like this.
  22. XJ550H
  23. hogfiddles
    It doesn't matter if the needles are sealing or not, if the gasket is leaking. If gas is leaking out, the level will drop,the needle will open, and more gas runs in......either way, the process continues.
    If the fuel supply tube o-rings are leaking, the fuel valve will be of no consequence, there, either. The fuel supply tubes and o-rings are in line BEFORE the fuel valve.
    So you do need to break the rack down and do the whole thing correctly.
    rocs82650, k-moe and XJ550H like this.
  24. rocs82650
    Middle Tennessee
    And then was...D@mn, y'all smell something burning? FIRE!' :eek:
    Gary H.
