How to remove drive shaft from a 82 xj750
Discussion in 'XJ DIY How-To Instructions' started by jerryburns05, Jan 29, 2012.
  1. jerryburns05
    jerryburns05 New Member
    I have a 82 xj750 and I'm stripping everything off and cleaning and re painting everything. I'm down to just pulling the engine but I've never dealt with a drive shaft before and I'm wondering if anyone knows how to safely remove the shaft from the engine?
  2. iwingameover
    iwingameover Active Member
    roll the bellows back from the engine side and remove the 4 bolts holding it to the flange.
  3. hogfiddles
    That is how you unbolt the u-joint, of course the shaft will be away from the engine but you may find that THAT whole end is still in the way/nuisance.
    What I'd do is pull the rear wheel off. Then pull the 4 bolts that hold the rear housing onto the swingarm. Pull the housing and the shaft out.
    So, there's a couple different ways you can do it. Do whatever one works best for you.
    Dave F
  4. jerryburns05
    I haven't even looked that closely at it yet. I just wanted some input before I started tearing into it. Thanks for the input, I appreciate it.
