XJ550 - Pistons
Discussion in 'XJ Modifications' started by cmoore, May 11, 2010.
  1. cmoore
    cmoore New Member
    Auckland New Zealand
    Hi, does anyone know of a piston that can fit the 1981 XJ550...i am looking to take the motor out to 599cc and need 60mm pistons....i hear rumors of Kawasaki pistons that fit straight on etc etc....
  2. Kickaha
    New Zealand
    GPZ600 are 60mm, dunno what the gudgeon pin size is though
  3. cmoore
    cmoore New Member
    bloody hell kickaha....i go the other side of the world to ask and you pop up from next door!!!........so i can find pistons the right size and with the correct gudgeon pin size and with rings.....but other then checking physical dimensions....is there anything else to consider??
  4. Maan
    Maan Member
    Karachi, Pakistan
    Gudgeon pin to crown and skirt bottom to crown measurements must be measured too I believe. Also it makes the choosing process alot easier if the stock piston is kept handy for comparison purposes.
  5. Kickaha
    New Zealand
    Lots, although if the piston is "taller" a spacer under the barrel may sort it out, if it is "shorter" it may be a harder fix
    pistons around the 60mm (I've done a fair bit of looking)
    GPZ600 60mm
    VF500 60.4
    CB650 59.8mm
    CBX550 59.2mm
    GSX250E 60mm
    FZR600 59mm
    There's a 60mm set of Wiseco XJ550 pistons on ebay cheap, but they have no rings with them
  6. xj550Rider
    xj550Rider New Member
    Auckland, New Zealand
    BUMP! Also from NZ :) looking for pistons for my XJ550 secs 1981. Any ideas? 57mm... but I'm willing to go bigger as long as I can find some :/
  7. Kickaha
    New Zealand
    Have you measured the bore to make sure that size is what you will need? XJ600 will fit in with a rebore and are 58.5mm, I did that with my last one
  8. Boring bloke
    Boring bloke New Member
    Ramsgate
    Does anyone know if the 600 head has bigger valves than the 550 head? In order to maximise the benefit of going big bore.
  9. Kickaha
    New Zealand
    Yes it does but I cant remember the sizes, you lose the rev counter drive though as on the 600 it is electronic
