How did you hide your rat's nest or clean up your wiring?
Discussion in 'XJ DIY How-To Instructions' started by bandreso, Dec 13, 2009.
  1. bandreso
    bandreso New Member
    Hi folks,
    I've been searching these forums for a long time and getting some great inspiration and tips. I've chopped my 82 Maxim 650, and I'm working out how to hide a lot of the wiring. It already has the upgraded fuses. (P.O. did inline blades).
    What I'm curious is for the differen methods of relocating the Rectifier and the TDI... Project Enlosures used? Using the old Air Box if you put pod filters on? What's everyone been doing for cleaning them up and who has pictures?!?
    Cheers!
    ~B
  2. TIMEtoRIDE
    http://www.xjbikes.com/forums/index.php?threads/16109
    Anything is possible- - this guy put the battery in the tail, and hid the rectifier and ignition somewhere, leaving just AIR in the center of the frame.
    Depending on your exhaust, and if you remove your center stand, you have alot of room under the swingarm for alot of stuff.
  3. bandreso
    bandreso New Member
    Thanks T2R
    That is one sick cafe racer! I'm certain there's plenty to do with enough stick-to-it-ness. I have an aftermarket exhaust that the P.O. put on, which isn't blocking too much space... Never considered the center stand removal... That's going to take some weighing of the pros and cons. I've had plenty of time on a new bike that doesn't have one, but found myself witshing it did at times when doing work on it.
    That's a pretty sweet pic and good start. More pics are encouraged if anyone comes accross this...
  4. saftie
    New York, NY
    Link no longer works?
    Would be interested in the same..
  5. CaronaJoe
    CaronaJoe New Member
    Kansas City Mo.
    image.jpg I was able to mount everything on the frame rails under the gas tank of my 82 650 maxim. Cut down the wiring harness and you can't see a thing.
    willmarmnxj650 and MrJason33 like this.
  6. sine80
    sine80 New Member
    Tacoma, WA
    Here's what I did... Built a box and suffed wires in the box. Not pretty but seems to be working.
  7. FtUp
    FtUp Well-Known Member
    pacific northwest
    welcome to the forum, the link above seems to work for me.
    FU
  8. willmarmnxj650
    willmarmnxj650 Member
    Willmar mn
    Do you have close up pics of the wiring front to back?
  9. XJ550H
    that was corona joes only post try starting a conversation with him he will get an email
    willmarmnxj650 likes this.
  10. willmarmnxj650
    Willmar mn
    I remember seeing a thread on here awhile back of someone making the minimal wiring harness on a piece of particle board does anybody have any clue to what thread that was under? I thought that was a great idea to do
  11. XJ550H
    yup you take your existing harness and put it up on plywood or partical board.
    hold in place with nails and zip ties mark out where the connectors are that you want to keep, remove most of the wrap map your wires and colors and remove harness and run your wires from point to point.
    label and make a list 5 foot red /w wire from conn 1 to conn 2 ect . Detail records and you can reproduce them for another bike from tour photos and detail list
    I used to make harnesses for the first one i would hang the harness twice and leave it on the board for referance
